Go Back   Binder Planet Forums > General Forums > Tractor Tech
Old 07-22-2012, 04:53 PM
460 460 is offline
Default 544 starving
Our 544 with the 4 cylinder gas motor is starving. I cleaned the carb and bowl and drained the gas when i put fresh in it only runs with the choke on i can adjust the choke to make it run smoothly but when the choke is off it dies out.
Old 07-23-2012, 02:31 PM
BERMUDA KEN's Avatar
BERMUDA KEN BERMUDA KEN is offline
Default Re: 544 starving
Check the fuel supply upstream from the carb. The screen/sediment bowl assembly under the tank can fail and fill with dirt.
Take the fuel line off at the carb and turn the fuel on. It should gush out like Niagra Falls. If it does not, the problem is in the strainer and or fuel tank itself.
Always searching for IH 4300 Transtar Eagle Brougham items.......
Cub Cadets...Built for those who know better.
Old 07-24-2012, 07:22 PM
460 460 is offline
That is all good. when I had the carb off I noticed the rubber carb elbow was cracked. I taped it but Im not sure about it. Its missing too so I think maybe plugs too. Its sat for years.
carb , carb. , cracked , cylinder , fuel , fuel line , fuel tank , gas , plugs , problem , rubber , tank , turn
Fuel starving issues Rascus General IH Tech 27 11-11-2010 09:10 PM
392 fuel starving Michael Caffrey General IH Tech 7 04-08-2004 08:45 PM
Need help on a problem about my 544 diesel tractor Tony Diesel Tech 2 05-04-2002 03:22 PM
