Go Back   Binder Planet Forums > Special Interest Groups > The Skunkwerks
JustIH Binder Bash 2013
  #31
Old 07-15-2012, 05:52 AM
ruderunner ruderunner is offline
Default Re: 70 Travelall Chassis Swap Question
The 10x0 series trucks use front axles coded FA8 or FA9, disc brake were optional on 70-73 versions of those and a knuckles out swap fits 61-73 (67-73 use the same spindle, 66-down are a little different)
Search "travelall disc brakes" for lots of reading on this topic...
Swaping to 4wd is a major pain on the 10x0 trucks due to the front suspension and frame design, all the other 1x00 trucks use front leaf springs, hence easy conversion. 74-75 100, 200 also use ifs and a a pain to convert.
  #32
Old 07-23-2012, 11:35 PM
DavidWTravelallfan's Avatar
DavidWTravelallfan DavidWTravelallfan is offline
Send a message via AIM to DavidWTravelallfan Send a message via Yahoo to DavidWTravelallfan
There is no real advantage to the tahoe over the travellall setup other than the overdrive and maybe 5-8mpg more gas mileage . For the money you could sell the donor do a 4x4 setup. Then add Throttle body fuel injection on the 392 and maybe even a 4l60e swap behind the 392.[/QUOTE]
You may loose most of that 5-8 mpg gain since the travlelall body is allot heaver then the Tahoe body. A fully stripped TA body w/o doors, interior and glass is around 4K.. by itself.
72 Travelall 1200 4x4, 392. Im the "Picasso" of rattle can paint jobs.
100 , 1000 , 1970 , 200 , 2wd , 4bbl , aftermarket , ball joint , body , chassis , chevy , engine , frame , holley , mounts , overdrive , parts , question , scout , suspension , swap , tach , tires , transmission , travelall , truck
Chassis to body Question Scrapman General IH Tech 1 02-20-2012 05:53 PM
Another engine swap question stageman General IH Tech 7 10-03-2011 04:50 PM
Travelall restomod question J.B. Binder Builds 1 08-24-2011 09:34 PM
345 67 Travelall fuel feed question ollie General IH Tech 9 10-26-2004 05:21 PM
65-68 Travelall 2WD-4WD rear axle parts swap LeeC General IH Tech 34 05-22-2004 11:40 PM
