Go Back   Binder Planet Forums > IH Clubs > Member-Club Forums > Great Lakes Binders
  #271
Old 06-02-2012, 09:14 AM
Jeff Jamison Jeff Jamison is offline
Y-Block King
Default Re: Great Lakes Trading Post
I have a good hood for a 74 in Pa.Dont know how far you want to drive for one.
Jeff
74 travelette(rare breed)73 travelall(show truck)
68 travelall(12 years into ground up no end in sight)79 scout(4"lift)85 bus(moble shed) 64 scout 80(daughters) ,79 glass traveler(wifes)74 scout(in peices) more to be added when found
  #272
Old 06-07-2012, 10:44 AM
acercparts acercparts is offline
Nevermind
  #273
Old 06-08-2012, 09:53 PM
troyi73 troyi73 is offline
have a new set of steel qp tail caps and rocker panels for sale take 700 for all of it fits scout II
  #274
Old 07-12-2012, 02:42 PM
Justin H's Avatar
Justin H Justin H is offline
Send a message via AIM to Justin H Send a message via Yahoo to Justin H
I have a t90 3 speed trans. and a dana 20 t-case from a scout 800. The trans. has been disassembled but the d20 is still complete. All the parts are there. I no longer need either since I am doing a t18 and a dana 18 twin stick swap. Free for the taking if you want it, otherwise they'll go to the scrap yard.
PM or call (616)644-0354
1968 Scout 800
1977 Traveler Diesel
1966 Toyota Landcruiser fj45 SWB
  #275
Old 09-12-2012, 12:43 PM
JSchubzIH JSchubzIH is offline
Exclamation Re: Great Lakes Trading Post
Hello, first time poster, long time Binder...
Due to family circumstances, I may have to sell my 79 Scout II 1Ton
It is a beast, built to wheel...
Body/Frame -
79 Scout II, cut fenders, original frame
D and C Extreme Roll cage w/CB bars
Jeep Grand Cherokee leather seats
1/8" steel diamond plate floor
Custom rear inner wheel wells
Rocker-sliders
Engine/tranny -
345 4bbl w/snorkeled intake / T19 Granny low 4spd. / Dana 20
Suspension -
Front - Rancho 44044 front springs, reverse offset, Rancho 9012 shocks, F250 shock towers, extended shackles, , adjustable bump-stops
Rear - F150 reversed leaf springs, Rancho 9012 shocks, F250 shock towers, extended shackles
This Scout is low slung for a low CG, and extremely flexi. I built it for general trail use, and mild rock-crawling. It did not build it to be a 'mud-bogger', but is certainly capable.
1 ton axles -
D60 front - Detroit Locker, 5.13 gears, custom high steer arm w/10deg correction, Wagoneer pitman arm, Custom High Angle Driveline front driveshaft
14 Bolt rear - Yukon spool, 5.13 gears, shaved 1 1/4", disk brakes
All new bearings, races, and seals. Gears professionally installed. Painted with POR-15
Wheels/Tires -
Custom made Stazworks 'IH' double-beadlock rims 12x16.5 (The only set on the planet, I think)
39.5 x 18 x 16.5 Interco Super Swamper Boggers
$9500 or best reasonable offer
I am located in Watertown, Wisconsin, and shipping is not an option, pick-up only
If interested, reply to this post, or send me a PM.
(I guess I got a bit long-winded, but gave as many details as I could)
I will be taking pictures soon, and I will post them here. I will put my user name in the pic, so you don't think this post is 'spam'....
Thanks,
~Jeff
  #276
Old 09-14-2012, 01:18 PM
TimGott's Avatar
TimGott TimGott is offline
Send a message via AIM to TimGott
Default Enduro Bike
Hey gang, just thought i'd see if anyone here is interested in a 1984 Yamaha XT600 Enduro bike, its titled, running and riding, someone converted it to off road status (no blinkers,horn,tail light etc) but the wiring is still there if you were ambitious) I'm trying to get rid of my non IH stuff so I can focus here.. (I get sidetracked pretty easily) Its about as pretty as an 84 off road motorcycle should be its been ridden, and beat up a little, but she still goes pretty strong! if you want info or any questions hit me up timgott@hotmail.com
im asking $800 but im open to trades..
66' 800 1/2 cab, still in planning stage..
74' scout II in various stages of resto... if I spent as much time on it, as I do on the BB It would've been done a year ago!
Great Lakes Binders!!
  #277
Old 02-28-2013, 01:14 PM
Bares62IH's Avatar
Bares62IH Bares62IH is offline
Any one have a 4 bolt Chevy 350 or 305 , and np205 tcase or sm465 tranny
Let me know what you got looking to spend under 400 for each item
Barrett
1962 Scout 80
  #278
Old 03-01-2013, 06:27 AM
michigan scout's Avatar
michigan scout michigan scout is offline
There is a yard by me that prices are really good and they will have what you are looking for. R&R Salvage 517-675-7288
80 4wd Terra Diesel-az rig
78 (345)4wd scout2 RHD CO
75 150 travelall 4wd TX
74 200 (345)4wd p/u KS
74 100 (392)4wd T-all Cali/mex
73 1110 (Olds 350)2wd short stepside MO
63 1/2 cab 80 plow scout
A few parts rigs
345 , automatic , body , cam , cylinder , diesel , distributor , door , engine , ih parts , oil , paint , parts , piston , rust , sale , scout , scout ii , soft top , storage , terra , top , truck , two barrel , zinc
