Go Back   Binder Planet Forums > Special Interest Groups > Injection Tech
  #211
Old 07-02-2012, 11:05 AM
79jeepincj7's Avatar
79jeepincj7 79jeepincj7 is offline
Default Re: Data Logging Help
A very good learning experience indeed!
Thanks so much!
So now back to the 350 tunes. That file that I sent you. Thats the 350 BIN you sent me before for a manual trans and an upgraded timing map. Could you double check that for me please? Then if all is well after this weekend I will flash another chip and see how it runs with the 350 tune instead of the 360 tune.
79 CJ7, Chevy 350, Junkyard TBI, Locked Dana 44 waggy and scout f&r, 36's, 1.5 RE SOA front, OME XJ SOA rears, XRC8 winch and custom front and rear bumpers with winch mount and tire carier.
Updates to come: Full cage and Tube Fenders
  #212
Old 11-13-2012, 10:29 AM
Hey Bill, so what would happen if you tried to run a tbi 350 with its factory harness and computer just without the auto hooked up anymore with the auto tune still?
  #213
Old 11-13-2012, 10:43 AM
Bill usn-1's Avatar
Bill usn-1 Bill usn-1 is offline
Moderator
Nothing.
With the auto bin and nothing hooked up the ecm sees it as being in gear all the time.
You still need to get rid of knock and EGR and VSS if not used.
Bill USN-1
Click a link below that meets your needs! Either DIY or let me help.
COMMITED TO HELPING PEOPLE "PROPERLY" INSTALL EFI
Learn to do it right.
May be the answer to all your fuel injection needs!
WANTED-Holley Distributor
  #214
Old 11-13-2012, 10:45 AM
scorp1us's Avatar
scorp1us scorp1us is offline
Well the engine runs the same. There might be some fall-off parameters that are different for easier shifting. But I've flipped the flag myself. All my PCMs are autos, but running a 727, I set the flag to manual. is that what you meant?
1980 Traveler 345 D44, 3.73, 727, 4" RC SUA w/4* shims, GM 350 TBI (16197427)
  #215
Old 11-13-2012, 11:15 AM
Well you both answered my question. Would you happen to have a BIN for a manual trans bill? Possibly with that hotter timing curve?
Thanks!
Ill just flash a new chip for it as an manual if I have to get rid of the other 2 sensors anyways.
  #216
Old 11-13-2012, 11:30 AM
Bill usn-1's Avatar
Moderator
I would recommend just starting with the ASDU as mentioned in the FAQ's.
It is a 5.7auto and works fine.
Just copy and paste the timing table into the table and make the basic chip adjustments per the FAQ.
No need to set the manual bit.
If you want me to set you up a bin then you have to go to the machine shop forum and look up Hamilton Fuel Injection. Or click the link in my Sig.
Bill USN-1
  #217
Old 11-14-2012, 07:59 AM
So for the timing table I imagine you are talking about this one? http://www.binderplanet.com/forums/a...7&d=1303754596
Thanks!
  #218
Old 11-14-2012, 09:51 AM
Bill usn-1's Avatar
Moderator
Yep, that will get you started.
Bill USN-1
  #219
Old 11-14-2012, 09:53 AM
Thanks! so thats a little bit hotter then the stock chevy table?
  #220
Old 11-14-2012, 10:07 AM
Bill usn-1's Avatar
Moderator
Actually if you are back to the 350 chevy then that table may be too much depending on the year.
If it's one of the older carb 350s then it should be fine.
If it's a later swirwl port or lean burn then the table may cause ping.
Bill USN-1
110 , air cleaner , cable , cam , chevy , ecm , engine , faq , faq's , find , fuel , grind , knock , number , panel , plug , rich , start , starting , tach , timing , truck , tube , vacuum , voltage
How to read and change the program in your GM ECM! Bill usn-1 Injection Tech 30 01-15-2012 12:16 PM
Step By Step Real World Build Up!!!! STOP--READ FAQ FIRST Bill usn-1 Injection Tech 36 03-11-2009 12:29 PM
Logging Data...Getting Started 81eagle Injection Tech 13 04-23-2008 03:49 PM
Guess Who's Got DATA!!! Carl Wiese Injection Tech 48 10-12-2006 12:20 PM
Brand new data! I'm finally logging. Chrispucci Injection Tech 24 09-10-2006 02:15 PM
