  #11
Old 06-04-2012, 11:48 PM
Eric VanBuren's Avatar
Eric VanBuren Eric VanBuren is online now
Dreams of Cub Cadets
Default Re: Lock-o-Matic Drag Shoe Nut Sources?
I've never seen or heard of plastic lock washers. Only the very earliest versions of the unidirectional Lock-O-Matics use lock washers with drilled holes instead of slots. Those nuts are also unusual in that they had a single pointed set screw. Pretty early on they switched to the slotted washers and nuts with 3 dog point set screws. This was done as a safety feature so that you can always get 2 set screws to enter the washer.
The late model lock nuts used on Ford and GM vehicles are used with drilled washers. Those are the ones Bill suggested could be made into Lock-O-Matic or Automatic drag shoe nuts with time on a lathe, drilling and tapping holes for the set screws and spanner and maybe a little welding.
  #12
Old 06-11-2012, 12:31 PM
Mark Pietz Mark Pietz is offline
After ruminating on this thread and the other big one you wrote, last night I drug out the two loc-o-matic hubs I obtained from different sources (junk yard and this forum) to clean up and eventually install on my 1980. I also pulled out a large coffee can in which I had put miscellaneous nut-type hardward from other sources over the years. Not realizing the difference in ODs, I set about miking these things...have about four of the 2.25" jobs, and discovered that the "matching" hardware sent by the guy I bought a hub from, was also 2.25". Huh...good thing I checked. All those were pristine. I have four that are 2.125" - one is rusty and useless, and the other three have only two of their three screws useable, the third being buggered up....using punches is obviously the favored method of tightening these rings.
IC 196, 4-speed, 3.73 gears
  #13
Old 06-11-2012, 04:12 PM
graedin's Avatar
graedin graedin is offline
Originally Posted by graedin View Post
Boy, I only found one vendor who had them, and used at that. Thank you SSS! And good luck to the rest of you, I bought them out! These things are getting super hard to find. I have been able to find a couple of sources that have the 2.25" nuts, but a HARD time finding the 2.125" ones.
Well, , SSS sent me 2.25" lock nuts!!!!
DOES ANYONE HAVE A SET FOR SALE THAT MEASURE 2.125" OUTER DIAMETER???
"Tonka" 1972 Scout II 'Glass Body / Corbeau LG1
345/727/D20/3.73 D44s / 31x12.5 ProComp ATs
TSM Rear Disc / 68 Vette Master / Eldo Calipers
MSD6AL / Pertronix / Painless Wiring / Elec Fan
  #14
Old 06-11-2012, 08:32 PM
DAGATOR16 DAGATOR16 is offline
graedin-
I have a couple I'll sell you. $20 each plus shipping work? IM me and we can work it out.
The left one is a larger nut for an automatic hub. The two on the right are the smaller nuts.
1974 SCOUT II, 345 AUTO
1980 SCOUT II, 304 AUTO
automatic , box , brake , dead , decal , find , free , hard to find , horn , hub , lock , lock-o-matic , matic , number , parts , remove , safety , scout , screws , starter , truck , universal , vendors , warn , website
Spindle nut lock washer ? Austin General IH Tech 4 06-02-2013 04:57 AM
dana 60 full floater spindle nut questions Blake W General IH Tech 4 06-04-2005 12:05 PM
Manual hubs vs lock-o-matic / interchange-ability David Alt General IH Tech 12 01-25-2005 01:32 PM
