  #111
Old 03-04-2011, 05:32 PM
Thomas's Avatar
Thomas Thomas is offline
Dreams of Cub Cadets
Default Re: Useful Part Number List
Originally Posted by gillis51 View Post
Welch plugs, apparently Dorman 550-015 (steel) are not available any longer, at least I couldnt find them. Try Napa 381-1010.
---I don't like using this thread as a chat box, but they are still available. I have posted the numbers at the end of my post in this thread (#10), consisting of all I could find (if I missed any, let me know) including the Rocker Arm Shaft End Plugs. All numbers for steel or brass. His link was dead because for some reason it read dormanproducts.com/dorman/p-22159-550-015.aspx when all it needed to read was dormanproducts.com/p-22159-550-015.aspx
T.R.E.Jr.(Fortiter Et Recte)
74 T'top (304,e2300,Unilite,Skyjacker,BCB U-bolt Plates,T-19=StoneThrower
53 Farmall H=Heinz
49 IH fridge=?
Who loves hearing,
"We replaced this & that & the bill comes to $x,xxx.xx ... but we couldn't find the problem. What payment method will you be using?"?
  #112
Old 03-14-2011, 09:29 PM
bradmoulton's Avatar
bradmoulton bradmoulton is offline
Found a boat load of part numbers at www.cornbinder.com
may or may not be up to date.... try it.
MEMBER: www.cornbinder.com - The Community for IHC Enthusiasts.
  #113
Old 03-19-2011, 10:28 AM
DavidWTravelallfan's Avatar
DavidWTravelallfan DavidWTravelallfan is offline
Send a message via AIM to DavidWTravelallfan Send a message via Yahoo to DavidWTravelallfan
71-73 Travelall 392 W/ a/c, no smog pump. Power steering- Dayco 15455. Just bought from Advance auto Mar 2011. Matched old belt to fit.
72 Travelall 1200 4x4, 392. Im the "Picasso" of rattle can paint jobs.
  #114
Old 05-15-2011, 09:51 AM
TUselton's Avatar
TUselton TUselton is offline
1979 Scout 2 Ignition Lock Cylinder - fits Tilt Column (and possibly others?)
NAPA Part #: KS6588SB
~$15 at the time of this posting - came with two keys.
Napa had it in stock at my local store.
1968 1100B - "Lilly"
1966 800 - "Mighty Mouse"
1979 Scout 2
1952 IH Freezer
1977 Airstream - 31' Sovereign International
  #115
Old 05-25-2012, 11:29 PM
Will Marsh's Avatar
Will Marsh Will Marsh is offline
Moderator
Replacement Fan Clutch and Fan for 8 bolt water pump (not threaded style). All SV8 and I4 engines in Travelall / Pickup and ScoutII's. Probably not Scout 80/800's.
Hayden 2741 clutch
Hayden 3618 fan
Each available from Summit Racing for under $40 today.
You need a minimum of 4" from the fan mount surface of the water pump to the radiator. The center of the clutch sticks out 3.5", and the front of the fan is .5" behind that.
Will Marsh
I don't know the key to success, but the key to failure is trying to please everybody.
Bill Cosby
www.redstate.com
Buy my wife's book (so I can buy more IH trucks! )
  #116
Old 12-24-2012, 03:58 PM
scoutboy52's Avatar
scoutboy52 scoutboy52 is offline
Part # for the O-ring in the oil pump pick-up - 79 scout II?
Aaron Gundlach
1972 Scout II - 345, 4-sp, D44 front & rear.
1979 Scout II - 345, auto (plow truck)
1979 Scout II - 345, auto (Texas truck) future restoration
  #117
Old 01-26-2013, 03:11 PM
Comanche Scott's Avatar
Comanche Scott Comanche Scott is offline
Default Carburetor Balljoint link
For the mechanical rod type carburetor linkage (as used on the Scout 800 V8 model).
I found Napa PN 2-685 works great.
As you can see by the pictures it is about 3/8" shorter than the original, but there was plenty of adjustment available.
The ball stud is 10-32, and the female end is also 10-32.
Cost was a bit under $11.00, and it's made in America!
Hth,
Scott
1971 800B Comanche 304, T98, D20, Scout-II D44 w/disc, D44 rear w/Power-lok, Hydroboost, Scout-II P.S., 8K Winch tucked in tight.
August 2012, "the build" begins:
4BT, 4L60E, Dana 300 w/Tera-Low, Linked, lifted and stretched (just a bit).
  #118
Old 01-26-2013, 04:58 PM
cAlvis165's Avatar
cAlvis165 cAlvis165 is offline
Default 1" slave cylinder and master cylinder rebuild kit
Had a hard time finding these parts, so I thought I would add them. Napa has the wrong slave cylinder listed for my '65 1300 4x4 pickup. They list, NCF 73471 $38.99. But it required spacers in order to mount it.
The correct Napa part is NCF 73463 $17.10
Also rebuilt my original master cylinder. 1" brake bore, and 7/8" clutch bore.
Napa rebuild kit #s
UP 234 7/8" $18.49
UP 253 1" $19.80
Success is not final, failure is not fatal: it is the courage to continue that counts. Winston Churchill
Project Dooley http://www.binderplanet.com/forums/s...134#post768134
  #119
Old 04-30-2013, 11:55 AM
Tonyb Tonyb is offline
Scout 800b windshield washer fluid pump; ANCO 64-01 - may fit others.
345 , axles , borg warner , brake , brakes , broke , case , conversion , diff , egr , engine , master , number , oil , part , parts , rear brakes , scout , scout ii , steering , thermostat , timing , truck , warn , water
