Old 05-21-2012, 07:53 AM
Mark Pietz Mark Pietz is online now
Default T19 rear seal question
Not having paid attention to the old rear seal in that large iron adaptor when I tore this all apart, now I have to ask. Which way does the new seal go? The metal shell isn't exactly open on one side which would make it easy. I have a seal with a large lip inside, then a smaller lip. I think the large lip should go towards the trans, the thin lip to the transfer case. I'd imagine this would also be the same as for a T18.
Thoughts?
IC 196, 4-speed, 3.73 gears
Old 05-21-2012, 11:37 AM
fredsterra's Avatar
fredsterra fredsterra is offline
Default Re: T19 rear seal question
There is normaly a spring on the outer lip. That goes to the inside or wet/oil side. And you can look at the lips of the seal and tell if "oil would run under or push down" That is kind of an old school way of doing it. You want the oil to push down not run under.
Mark Fredrick
Madisonville Ky
1978 Terra 345 V8. Edelbrock 1406 carb, MSD,Pertronix, 392 4V Intake.
1974 Scout II "Tiger" Soft Top 4X2 (My Bride's Scout)
case , oil , question , rear , seal , spring , t18 , transfer case
Trans. Shift Lever Seal Replacement DAGATOR16 General IH Tech 16 05-27-2013 10:41 AM
BD-240 Rear Main Seal R Pamer Triple Diamond Trucks 4 06-30-2011 10:49 AM
Rear Main Seal Replacement raleighrugger General IH Tech 12 08-28-2009 05:16 PM
Stupid Rear Brake Question - No Fluid Forcus General IH Tech 8 03-14-2008 07:35 AM
Rear Main Seal Ken C General IH Tech 25 01-19-2007 02:33 PM
