Old 05-13-2012, 02:42 PM
gillis51 gillis51 is offline
Default Turn signal indicator lights
79 Scout II 345, auto.
The turn signal indicator lights remain on at all times while the head lights are on. When headlights are off so are the indicator lights. When directional is used the indicator light blinks on and off. Is it normal for the indicator lights to stay on while the head lights are on or is it a ground issue? If ground where to start. I have great ground from battery to block back to tub.
Thanks
Old 05-13-2012, 05:00 PM
Eric VanBuren's Avatar
Eric VanBuren Eric VanBuren is offline
Dreams of Cub Cadets
Default Re: Turn signal indicator lights
It is your ground for the TS/park light buckets, the parking lights are grounding through the TS indicators.
Old 05-14-2012, 08:10 AM
fredsterra's Avatar
fredsterra fredsterra is offline
Yep sounds like a ground issue on the front turn marker lamps. I had iisues 2-3 times. And wound up running an extra ground wire from the housing to the frame. Clean the ground contacts and I use a dab of Antiseize to help prevent just at the ground spot.
Mark Fredrick
Madisonville Ky
1978 Terra 345 V8. Edelbrock 1406 carb, MSD,Pertronix, 392 4V Intake.
1974 Scout II "Tiger" Soft Top 4X2 (My Bride's Scout)
Old 05-14-2012, 10:29 AM
Thomas's Avatar
Thomas Thomas is offline
-As noted,
---Further explanation (I have posted wiring diagrams from my* shop manuals for some time now and they, along with solution to this problem can be found through a search), the Parking Lights ground at the fender, fender grounds to frame, frame is connected/grounded to the battery, battery has ground jumper to fender, fender has ground jumper to cowl, cowl grounds to door pillar, door pillar to kicker panel, dash grounds to kicker panel & headlight switch grounds to dash. The #11 circuit physically has two grounding points. First is the technical ground, at the dash speaker mounting stud behind dash, near ash tray. Second is the mechanical/physical ground, at the bucket where it mounts _to the fender. Look here for a description of a "fix" (boogers, tape and/or gum) I made in 1995 when I first sensed that sheet metal, seams & corrosion were an annoyance to StoneThrower. StoneThrower did have all the factory ground jumpers, but the cowl to kicker, kicker to dash weakness wasn't expected and the speed nuts & screw style fastening is fine, but inadequate for grounding.
---Completely remove the parking light bucket & you'll see. If you happen to have the lights on while doing this & notice the parking lights get brighter while turning a lenses screw, do not* just simply snug them down. That is the road to cracked lenses & new aren't always reasonable in price.
T.R.E.Jr.(Fortiter Et Recte)
74 T'top (304,e2300,Unilite,Skyjacker,BCB U-bolt Plates,T-19=StoneThrower
53 Farmall H=Heinz
49 IH fridge=?
Who loves hearing,
"We replaced this & that & the bill comes to $x,xxx.xx ... but we couldn't find the problem. What payment method will you be using?"?
345 , 79 scout ii 345 , battery , binderplanet , clean , cracked , door , frame , front , ground , headlights , light , lights , panel , scout , scout ii , signal , start , switch , tub , turn , turn signal
12 EZ, tractor turn signal switch, Brake lights. Towem General IH Tech 6 01-02-2011 12:04 PM
Turn signal switch on the way.....any advice? Smithflyfisher1 General IH Tech 6 02-01-2007 06:03 AM
turn signal switch scoutman800 General IH Tech 4 01-02-2006 12:07 PM
Turn signal problems ejstadler General IH Tech 8 05-20-2004 08:27 AM
Turn signal fix big steve General IH Tech 0 03-21-2002 09:18 PM
