  #31
Old 04-29-2012, 06:04 PM
SERENate SERENate is offline
Default Re: New Scout Project, can't keep it running w/o choke...
Snapped 2 off the back, and rounded off all of the front ones. I have no idea what I'm going to do to get them off.....
  #32
Old 04-29-2012, 06:21 PM
scoutboy74's Avatar
scoutboy74 scoutboy74 is offline
Y-Block King
Send a message via Yahoo to scoutboy74
Like Stu said, they're LH threads, as in righty loosy/lefty tighty. You're turning them the wrong way. That much white smoke from the exhaust would have me suspecting a blown head gasket. Got any chocolate milk showing in the crankcase?
Trever Whetzel
Fat White Boys
Binder Recovery
& Rehabilitation
SHOP NORTH
Hooty - '74 SII 4x4 - 392/TF 727/D20/3.73 D44 FA + Spartan/Trac-lok RA/4" SUA/33" TSL's/33g-fuel
Mongo - '71 1210 Reg Cab 2wd - 345/TF 727/RA 17 4.10 Trac-lok D60 - "Mongo love candy!"
  #33
Old 04-29-2012, 06:32 PM
Well I really screwed that one up!
Drained the oil and everything looked ok. Cleared up a little bit after running it today.
Any ideas how to get these nuts off????
  #34
Old 04-29-2012, 08:17 PM
stu simpson's Avatar
stu simpson stu simpson is offline
At this point, if you do not have a friend with a lug nut splitter (and how many of us do?) you will need to kerf the nuts as deep as possible with a cutoff wheel, hold them relatively stable and split them with a cold chisel and BFH. Then, remove the wheels, pull the drums and drive out the lugs and replace. Hope the holes aren't buggered.
Did you say you had a flanged D44 rear or the hub/axle D44?
Charter Member, F.O.P. (Friends of Poseidon)
  #35
Old 05-12-2012, 11:13 AM
Finally managed to get the lugs off and replaced all the studs on the drivers side. Got the wheels mounted and now I'm rubbing really bad.....
If its not 1 thing, its another!!!
Any cheap fix for now? Not really interested in doing a spring over right now....
  #36
Old 05-12-2012, 11:25 AM
  #37
Old 05-12-2012, 04:17 PM
joker51's Avatar
joker51 joker51 is offline
Looks like the springs are sagging a little. I would try putting in an extra leaf or even a lift kit.
Im thinking an extra leaf or spring helper (think thats what they are called) would be the easiest and cheapest route.
Found a suspension lift kit $865 at anythingscout. That might be a way to go also.
Joker51
Joker51
1979 Scout Traveler with SOA, 33" tires, 345, 727 tranny
196 , 800 , air , battery , brakes , cap , carb , clean , cylinder , filter , fuel , fuel filter , gas , holley , inspection , master , project , rebuild , scout , scout 80 , scout 800 , seat , top , valve , wheels
Holley 1904 woes Dan&Becky'sScout80 General IH Tech 8 04-17-2012 10:59 AM
Holley 1904 dumping gas on passenger side thetodd General IH Tech 18 11-28-2008 08:47 AM
holley carb kit biggomba General IH Tech 0 01-20-2008 10:51 AM
S120 IH Holley carb settings Britcheflee General IH Tech 0 08-08-2007 12:55 PM
Carb Rebuild Part Number for Holley 1904 4 cyl Jayrodoh General IH Tech 0 03-10-2004 06:55 AM
