Go Back   Binder Planet Forums > IH Clubs > Member-Club Forums > Hill Country Binders - Central TX
JustIH Binder Bash 2013
  #31
Old 04-19-2012, 12:58 PM
ziggybock's Avatar
ziggybock ziggybock is offline
Default Re: The Final Countdown...
Last night was put into overdrive mode to wrap up the steering and finalize a few other things.
First thing first, new hardware arrived and I was ready to slap it on. 1.25" spacers for the front.
I will add them to the rear later, just focusing on getting this trail ready for this weekend.
Without the spacer this is how much room there was in relation to the steering.
Now with the spacer installed
I will get to the steering improvements with the spacers in a few.
Next was installing the Z-bar. Big Tres to the rescue on this one. To set the alignment, we had a straight edge on the inside of both tires and took measurements and made adjustments til we had the same measurement on the front and back side of the tires measuring in-between them. Basically setting the alignment to zero. This truck is not a highway or even a road cruiser, so this should work well for me. If that ever changes later, I can always spend a couple of bucks and have it done. There might be a little tweaking that needs to be done after this weekend but I am pleased how it turned out.
All I can say after working on this during the install is this thing is heavy duty and built extremely well. Jayson at Canyon Offroad did a great job on this and provided everything needed to make this a quick install and upgrade.
Enough blabbing, I know you only want to see the pics anyways
The added feature of Ziggy's arse in the background is free....
Now with the spacers and steering installed, let's see if I am going to have any rubbing from the tires onto the srpings with this D30 CK...
NICE!!!!!!
Only thing left to do is figure out how I am going to get this thing on my trailer?? I have done a couple of quick measurements and it is going to be really, really close.
I think the war wagon is ready for this weekend and somehow I was able to get it all together, not perfect, but enough to try it out on Saturday. I really could not have gotten it in done in time without all the help and support from the group, thanks again everyone.
The raffle tickets for the war wagon is $10,000 a piece.
80/800 Hula Girl Club
  #32
Old 04-19-2012, 03:04 PM
Tres03's Avatar
Tres03 Tres03 is offline
Wow this thing is really coming along. I cant wait to see how it does this weekend. It really looks great Chris.
1963 Scout 80
SOA 36" hummer tires
6.2 Diesel, TH 400, 208
Scout II Dana 44's
4Wheel Disc Brakes
MY Build Thread
1967 Scout 800 Stock "Ranch Scout"
1968 Scout 800 "The GOLD Scout"
  #33
Old 04-19-2012, 03:58 PM
sullyscout77's Avatar
sullyscout77 sullyscout77 is offline
Great recovery Chris! Make sure you bring a tow strap for me!
1977 Scout II, 304, 727, DANA 44/44/20, "BUSTER"
1960 Travelall, 4X4, 3/4 ton, "WILBUR"
Sully
  #34
Old 04-19-2012, 05:33 PM
az scout guy's Avatar
az scout guy az scout guy is offline
Looks good Chris, glad it all worked out for you.
http://canyonoffroad.com/
76 Traveler
SOA
RS
High steer
Chevy 350 TBI
700r4
Dana 300 with 4 to 1
Dana 44's with OX locks
Chromoly axles front and rear
37x12.5x15 MTR's
Eaton Beadlocks
A/C
Autometers
Daily driver
  #35
Old 04-20-2012, 03:45 PM
ziggybock's Avatar
Thanks Jayson, I will put it to the test tomorrow and let you know how it works out. I'll post some action pics from the event, hopefully all these mods hold together!!!!!
4.2 , 800 , air , axle , compressor , d30 , drive shaft , front , gear , gears , group , hose , kit , mr scout , oil , rack , rebuild , rebuild kit , scout , short , tach , texas , truck , wheel , work
The final result.. DavidWTravelallfan General IH Tech 12 08-15-2011 04:54 PM
Navistar Statement on Final GHG/Fuel Efficiency Regulations from EPA and NHTSA Jeff Bade Navistar News 0 08-09-2011 09:50 AM
Final T-shirt design... Mike Moore Old Dominion Binders Association 9 05-28-2004 12:26 PM
Final COD Tee Henry Penry Diesel Tech 3 07-16-2003 10:05 PM
