#11
All that leaves is the pitman arm length or the gearbox. |
#12
Anybody have any experience with installing an "inverted "T" or crossover setup?
#13
1935 1210 steering tips
I didn't think they had 1210s in 1935,or power steering.
64 IH 1Ton,345,T34,T18,Np202,40"MTRs,crawl ratios,61:1,113:1,207:1,375:1,D70 front with ARB & 35 spline chromolly axles,RA15 rear with Detroit Locker,York on board air,custom 200 amp welder. Iraq veteran 04 |
#14
In 1935, the power steering was the 'Armstrong' brand!!
#15
The 2wd and 4wd steering box mounting brackets are usually different.
1976 Terra, 392 (awaiting efi), T-19 close, 2.47 Creeper Box, D-20, 3.54's, Detroit rear, Aussie front, 6 in. Alcan Spring SUA lift on 35's. 1979 Midas, 6.2L GM Diesel, TH400, D-20, 3.54's, stock axles on 33's. |
#16
Iam almost positive the bracket is different,get the correct pitman arm of of a 69 to 73 4x4 with power steering(74 and 75 are different)1/2 ton or 3/4 ton will work.I did the convertion years ago,on a truck I no longer have in one peice,and everything worked great by using all the factory 4x4 parts.(Dennis the boxes are different on 74-75 2 wheel drives only)
Jeff
74 travelette(rare breed)73 travelall(show truck) 68 travelall(12 years into ground up no end in sight)79 scout(4"lift)85 bus(moble shed) 64 scout 80(daughters) ,79 glass traveler(wifes)74 scout(in peices) more to be added when found |
#17
Thanks Jeff!
![]() Is that bracket made of any exotic materials like gold or unobtainabium? I don't know of any more 4x4 IHs in my area I can get any parts off of. The frame I got the dana axle from had manual steering. Just from memory, I can't think of any differences in the mounting bracket, then again I probably wasn't looking. Does it mount farther forward or back, make it sit lower, or just change the angle? Thanks everybody for your help! I was starting to gather parts for a inverted "T" setup, but my deep oil pan on my Perkins Diesel is totally in the way! It will take an extreme Z-link to get around the oil pan then the springs. I really didn't want to drill new holes in the frame to rotate the gearbox anyway. I'm not looking for a rock crawler, just a street truck mostly that will still be capable of occasional off road and snow. Mostly I just want it to drive better than a scout. |
#18
#19
I don't think so. I'm pretty sure I got brackets from 2WDs when I did two conversions in the past.
#20
I just looked up the bracket in my parts book and it states there are 2 brackets and a spacer bracket for the 4x4(237 614 r1) and there are 5 different steering arm for the steering gear,depending on axle code,so your bracket might be right and you just need the spacer
Jeff
| 1210 , 2wd , 4x4 , axle , axles , bearings , box , car , d series , dana 44 , drag link , find , front , gearbox , pickup , power , power steering , steering , sucks , tie rod , travelette , truck , turn , wheels |
| Frozen steering? | dgregg | General IH Tech | 2 | 11-19-2007 03:29 AM |
| power steering: HELP?!?! (pics) | dboy | General IH Tech | 5 | 06-03-2005 11:17 AM |
| looking for advice pwr steering set up | Todd J | IH Scouts & Trucks of Oregon | 2 | 04-29-2005 10:41 AM |
| Scout 80 Steering Upgrade | Larry Rivelli | General IH Tech | 18 | 04-18-2005 07:09 PM |
| Steering While Locked Front and Rear | Hooper | General IH Tech | 15 | 02-16-2003 08:30 PM |
