I've been lurking around here for a long time and I finally have a question that I can't seem to find an answer to. I felt like an idiot when I did it, but I cracked the transmission side of the starter mount on a 392ic that I'm rebuilding. Is this a JB Weld fix or does it need to be brazed? Has anyone had any experience with this product http://www.castaloy.com/ ? Thanks for any suggestions, Cooper |
Looks like there's enough to hold the dowel, the bolt hole should go all the way threw to the front?, if you want to weld it stick weld it with Nickle rod.
ASE mastercertified engine machinist, gas and diesel Brake and alignment specialist Agriculture/industrial tractor tech. 68 Rambler American 72 1210 4x4 77 ScoutII 88 Olds Cutlas Calais Quad4 5spd 97 JEEP TJ 99 Yamaha YFS 200 (248) Carlos Mencia said it! don't be a "DEE DEE DEE"! |
starter doesnt mount there, thats for the trans.
no big deal.. 5 other bolts hold the trans in place. becareful in the future ,ok? me i'd drill all the way thru it, and stuff a bolt and use a nut on backside. you could weld it all up and redrill and tap it, good luck with getting that perfect alignment.. |
put it together and run it,you'll be fine.jeff
jeffoh-'71-1210 t'all-'74-150 t'all-'69-1100-4wd-all- t'all/..'73 1010 wagon master (soon to be a 1110 4WD)..'73-1200 t lette 2wd,(soon to be 4wd) |
Since 3/4 of the way around of the portion that holds the dowel is intact just put the dowel in and run it with 5 but do not leave the dowel out.
jb weld is worthless for this.
If you were to braze or weld it you would have to grind a groove to fill up with braze or nickel rod. The idea of a thru bolt is a good one. http://www.muggyweld.com/?view=castiron Quote:
Thanks for all the replies! Sounds like it's not that big of a deal. I like the thru bolt if it doesn't interfere with mounting the starter. I'll have to take a closer look.
Cooper |
| alignment , choice , cracked , deal , exhaust , find , front , gas , glass , grind , manifolds , mount , part , question , repair , starter , transmission , welding |
| Ignition starter switch (how do I fix it back?) | Spirit_of_61 | Southeast Binders Association | 1 | 06-16-2010 08:31 PM |
| Starter wont stop cranking | anthonybalmert | General IH Tech | 8 | 03-10-2010 10:28 AM |
| Start Me Up... Starter Problems | GregnK | General IH Tech | 5 | 11-11-2009 11:14 AM |
| Sorta-Kinda Applicable Starter Info... | Eddie | Diesel Tech | 2 | 02-01-2007 09:10 PM |
| Intermittent starter failure -- ? | SpringtuckyPicker | General IH Tech | 1 | 10-03-2005 12:15 AM |
