After reviewing PYPES 2 ½” SS downpipes, it appears two of their “lower pictured” #DGU10S 78-88 SB CHEVY – 2 BOLT G-BODY downpipes with the longer run before the tighter than 90 degree bend will work. ![]() http://www.pysales.com/IW_Products.m...TI_ITEM_SUBMIT Does anyone that has Chevy and IH experience know if the exhaust manifold flared flange is the same on IH and the stated Chevy years on PYPES #DGU10S?
68 Travelall 4x4 Do-It-All-Rig: 392V8, T35, NP202, 4.11's, 14B, HD D44, 4" Lift, 4W Disc, H2's with 34.5" BFG AT's (Ongong project...) I can remember when the only carbs anyone cared about were under the hood!
How about you Hemi guys? These 2.5” SS PYPES downpipes for 70-74 E-body Dodge/Pylmouth 426 Hemi look to be the best shape for adaption to International with their dual ~45 degree bends. Cut them in the straight section between the bends and flip the flared flange up, then trim for an 85 degree combined bend to match the frame rail horizontal.
![]() http://www.summitracing.com/parts/PYE-DME20/ Anyone know what year model and make had this engine so I can look up and check the exhaust donut gasket for fit?
There might not have been an exhaust donut gasket on some of those. I know on the GM, the 'donut' so to speak is built in to the exhaust manifold, the flare just fits around it.
1979 Scout II soft top- CA truck, waiting for paint ![]() 1976 Traveler TX truck 'who knows when' 1969 IH 1000D pickup, summer driver |
Go back to your 'Summit' link and open the 'application' link. 1970-71 Dodge/Plymouth Challenger/Baracuda
Thanks, I'll give that a shot.
Pypes guy said they had a flared end, but I'm beginning to wonder... If it is a "flat" lipped mount then it may still work as the IH manifolds have a large enough circular flat surface that should be able to take an exhaust crush-ring gasket. The dual ~45 degree bends make these a likely one-cut and weld solution if the flange will work. I ordered up a pair of these based on the discussion with the Pypes guy. If I have to return them at least the shippng to me was free.
Looks like it's going to take one of these.
![]() Might work?
Lee,
I just bought 2 of these and some U bends from the local exhaust supply guy. Then went to the steel yard and found a small piece of tube that fit into the exhaust tube. Weld a short piece in, leaving about 3/4 of an inch to go into the manifold and you are set. Just add a donut and you are good to go. The piece inside keep the lateral movement down and keeps the donut intact. The exhaust guy gave me this tip, says all his circle track cars run like this. It's been a year and and all is still good. Before I could only go 3 - 6 months depending how many times I drove it.
1969 Travelall 1200D 3/4 ton 4 X 4 345 - 4 BBL Carter 500 - MSD Ignition - Auto Trans IH D60/Cheby D44 -Disc Brakes all around 6" Cheby spring lift Panties, not the best thing on earth, but next to it!! |
If you want to stay with the transition cone idea, check these out. I know you are doing all this yourself, so this might keep a few pennies in your pocket.
http://www.mandrel-bends.com/catalog...-cone-703.html
#9
I like your(his) idea on the insert to keep down lateral movement. Wish my manifolds weren't already installed so I could port and work with them easily. You can't believe what some of the prices are on SS mandrel bent exhaust pipe. It's shocking! If those downpipes work I think I can get by with just 2 additional 45 degree bent pieces for the transition from passenger to drivers side between the trans and TC and a little 2.5" straight stock. If I can keep the whole complete mandrel bent stainless steel exhaust system in the same $350-$400 price range as an installed aluminized system, then I'm good with that. Plus, I enjoy the process of doing something a bit unique. Check out the prices on Mandrel-Bend's site for their bent pipe kits. About $150 wihtout any flanges or straight stock and it might not be enough...
#10
The SS Hemi Pypes arrived. The end flange appears to fit the IH exhaust donut and manifold bolt holes just fine. Don't know why that exhaust gasket I looked up is shaped like it is
![]() ![]() I'll have to lay everything out and start planning my system in detail with all the parts I've order... MOVING THIS BACK TO HERE FOR THE EXHAUST SYSTEM BIULD.
| 1970 , 4x4 , body , bump , chevy , engine , exhaust , frame , full size , gasket , hose , international , manifolds , parts , project , question , racing , rim , short , size , start , travelall , tube , work |
| exhaust question | cornfed | General IH Tech | 2 | 02-22-2010 08:45 PM |
| Exhaust manifold gasket question | Marshall | General IH Tech | 5 | 09-20-2006 11:19 AM |
| exhaust manifold installation question | Tim Potter | General IH Tech | 4 | 09-10-2006 09:07 AM |
| Exhaust question | Michael Goodman | General IH Tech | 14 | 01-24-2002 09:29 PM |
| exhaust question | Jon | General IH Tech | 4 | 11-02-2001 06:27 PM |
