Yukon Warn Hub Conversion Brake Rotors
Discussion in 'SSII' started by Ian Topping, May 20, 2018.
  1. Ian Topping
    Ian Topping Farmall Cub
    Apr 6, 2017
    Hi all,
    We've been working to rebuild my Scout 800 with Dana 44s from a Scout II and decided to use Yukon's Warn Hub Conversion (part # YA W37132 (21666)). Went to install the Front Brake Rotors (stock Scout II rotors) and they don't fit over the hubs, the outer diameter of the hubs are too big for the inner diameter of the bell of the rotors. Anyone know which rotors need to be used with these hubs? Or, are we doing something completely wrong (which is certainly possible)?
    Thanks for the help.
    Ian
  2. WireGeek
    WireGeek Farmall Cub
    Apr 24, 2003
    7
    Mandeville, Louisiana
    The rotor should be on the inside side of the hub, meaning that the lug bolts would go through the rotor then through the hub. At least that's how it would be on the standard rotors and hubs.
    Good Luck!
