windshield frame removal
Discussion in 'General IH Tech' started by binder88, Sep 20, 2005.
  1. binder88
    binder88 Farmall Cub
    Apr 26, 2002
    no. of Evertt
    Ok how haed is it to pull windshield frame ?
    Mine is rusted beyond repair I have a replacement.
    Do you need to pull the dash or what??
    Thanks
    Brad
  2. Carl Wiese
    Nov 14, 2001
    8,169
    50
    Oregon City, OR
    Pickup/Travelall/Wagonmaster/Travelette?
    Scout 80?
    Scout 800?
    Scout II?
    Loadstar?
    Cargostar?
    Combine?
    1466 with a cab?
    Crawerl with a cab?
    :D :D Okay so maybe I got a bit exsessive, but could we please have a make and a year, my IH ESP isn't what it use to be.
  3. Gary Billings
    Jan 20, 2002
    4,391
    110
    Conifer, CO
    My ESP is working pretty decent on IH's with removable w/s frames :)
    On a Scout 80, there are a bunch of bolts on the top that go into the roof. Open up the hood, and look near the hood hinges... there are about 9 bolts along the bottom that hold the w/s frame hinge on. Take all those out and it should come right out.
    On a Scout II, there are the 4 screws in the top that go into the roof. Then, there are four bolts behind the upper door hinges that come out. Then, there are two bolts that are above the upper door hinges, that thread vertically into the height adjustment for the w/s frame. Disconnect the wiper motor plug by the heater assembly, push the connection through the grommet. Then, open the doors and kick the top of the w/s frame backwards towards the cab area. It should go. If not, a prybar between the roof and the top of the frame will work to help seperate it. Once you get the w/s frame backwards a little bit at about a 30 degree angle, lift it straight up and it will come out easily.
    I've pulled about 12 of them this way from junkyards and works great.
    -Gary
  4. JerryD
    JerryD High Wheeler
    Sep 12, 2003
    1,730
    Rockford, Michigan
    I dunno, your Effervescent Sarcasm Protocol seems to be working just fine, Carl. ;)
    Funny this is brought up, I've been contemplating this swap myself on my 1976 International Harvester Scout II XLC, formerly with an AM radio. :D From what the manual shows it doesn't seem too hard...
    Gary, thanks for the post. How long does it take you? I figure I'll multiply your time by 1.75 to get my time... :)
    Huh. How 'bout that. I thought you would've had better luck with a Shepard's hook. :eek: ;)
  5. John M
    John M Farmall Cub
    Jun 21, 2005
    35
    Portland, OR
    Hi, this seems like a good time to ask-
    Does anyone have any advice on how to properly adjust the windshield frame when it is reinstalled? I know that the windsheild adjuster bolts are at the top of the door hinge pillar caps, and I would assume one would adjust them outward until the windshield does not shake, but I have been unable to find anything in my manual ('77 SII) on how to do it right. Thanks!
    John.
  6. Gary Billings
    Jan 20, 2002
    4,391
    110
    Conifer, CO
    Nah, it's really not that hard to do. The hardest part is either taking out the roof bolts without the phillips head getting rounded out, or getting at the bolts behind the door hinges. You're ok if the head breaks off, but if the head rounds out for whatever reason, it gets to be a real PITA! Then you gotta pull the fenders to get at the backside of the bolts. My suggestion: use a 6 point 9/16" socket.
    If everything goes smooth, I can pull one in 10 minutes. If everything goes wrong...an hour. Of course this is on junkyard Scouts that I really don't give a s%#$ about, so there is more "abuse" going on.
    Wow, that joke will never escape me, will it!
    -Gary
  7. binder88
    Apr 26, 2002
    no. of Evertt
    yes sorry it is 77 scout II
    thanks
    brad
  8. surfcraft
    surfcraft Binder Driver
    Dec 3, 2004
    999
    SFV by the Sea, CA
    The manual gives a diagonal measurement from top of windshield header to top of body (where it meets top of door, strike side) at 35 3/4" .
    JW
  9. Beast1210
    Beast1210 Farmall Cub
    Mar 9, 2004
    109
    PNW
  10. Gary Billings
    Jan 20, 2002
    4,391
    110
    Conifer, CO
    Yes, you don't even have to touch the dash.
    -Gary
  11. Tim Potter
    Tim Potter High Wheeler
    Aug 6, 2002
    2,708
    La Habra, Ca
    Measure diagonally between the top of the door jamb (strike side) and the top of the windshield frame. "a measurment of 35 3/4" is considered correct" so saith the manual.
  12. Patrick Morris
    5,830
    772
  13. Stan Dowiat
    Stan Dowiat Farmall Cub
    Oct 19, 2008
    49
    Dalton
    On the Scout II... do you have to remove the front fenders to access those four bolts that go up into the windshield frame? Man... i can see then though the door jab but taking them out... much less getting new ones in looks impossible. thanks
  14. Patrick Morris
    5,830
    772
    No you should not have to fool with the fenders. All the bolts are accessible from the opened doors.
    And I think there's a total of six bolts holding the frame onto the body. If you look at either side you will see one that's vertical and is really easy to see/reach (and is also the adjuster bolt), and further in and oriented horizontally are the two more bolts that must be removed.
    FYI, when you remove all these six bolts you're not actually unbolting the WS frame itself; you are unbolting a couple of L-shaped brackets that the WS frame is actually attached to. With the six bolts removed you ought to be able to lift the WS frame straight up and off the vehicle.... provided the roof has been dealt with already.
