Where do you source your IH red engine paint?
Discussion in 'General IH Tech' started by rustfreeTX, Apr 16, 2019 at 12:53 PM.
  1. rustfreeTX
    rustfreeTX Binder Driver
    Apr 5, 2004
    673
    56
    Austin, tx
  2. mallen
    mallen High Wheeler
    1,961
    248
    I use tractor and implement paint I bought from CAL Ranch in Utah some years ago. Its
    "Case IH Red" and there is an optional hardner that I use with it. its held up really well.It did spend a summer with the hood off in direct sun for a year. Mine hasnt faded, but some people have reported van sickle paints becoming chalky and fading. I believe they had rattle cans too. I think they also have IH red which is apparently a slightly different color. You might ask at a good PPG dealer thats been around 30 or 40 years. They might be able to find a code for it.
  3. rdavisabc
    rdavisabc Farmall Cub
    Oct 12, 2010
    247
    81
    Arlington, Tx
    20181204_164249.jpg So keep this between you and me, but I use Chevrolet Orange-Red DE1607 :alucard: carried at O'Reillys and Advance Auto...
    Rd
  4. jeff campbell
    13,387
    720
    Oreillys have a nice red. $7.99 a can. Bug bomb.looks great to.
  5. Akremtukian
    Akremtukian Farmall Cub
    Feb 1, 2014
    33
    Kremmling, CO
    I used Duplicolor engine enamel, I believe it was universal engine red. 20180503_181740.jpg 20180517_192126.jpg
    stroker3 likes this.
  6. MrKenmore
    MrKenmore High Wheeler
    2,236
    469
    Ford Red (don't tell anyone!!!)
  7. Sammy
    Sammy High Wheeler
    Oct 22, 2001
    2,861
    266
    Grigsby's Bluff, TX
    Tractor Supply sells IH Red. They have it in rattle cans and gallon cans.
  8. Bud Seymour
    Bud Seymour Farmall Cub
    May 29, 2016
    137
    The Plains, Ohio
    Tractor Supply IH Red is what I’ve used with good success.
  9. Chris Cooper
    Chris Cooper Farmall Cub
    Mar 11, 2018
    179
    22
    KBS Coatings has an aerosol IHC Red. I haven't used it, so I can't attest to its performance.
  10. RinTX
    1,448
    298
    Tractor supply
  11. rustfreeTX
    Apr 5, 2004
    673
    56
    Austin, tx
    Thanks all, is the tractor supply paint for engines? I feel like it has to be high temp, not sure if regular paint would last that long. I know I've asked this before but did any of you use a primer coat, or just spray the red?
  12. MrKenmore
    2,236
    469
    You need to prep prep prep and then prep some more. You want to get any and all grease and crud out of there as paint won't stick to it. I did not prime with what I used on my valve cover. But I cleaned the heck out of it. Then applied a Prep-Sol cleaning solvent. This gets all the grease off.
  13. Akremtukian
    Feb 1, 2014
    33
    Kremmling, CO
    I used primer on mine
  14. stroker3
    stroker3 Dreams of Cub Cadets
    Feb 5, 2009
    4,586
    1,775
    Mass.
    This has been asked and there's always been mixed opinions on whether it'll last or not. In the past I've had decent luck with the TS regular paint on valve covers and such. While searching something else, I stumbled across this . Never tried it but it's supposed to be IH red engine paint.
    http://www.tacomascrew.com/Products...CyCUqC0ZmwvwfnqnudX4V8PhoHKtHRv4aApZdEALw_wcB
  15. George Womack
    George Womack Y-Block King
    Oct 13, 2001
    3,091
    179
    Terlingua, TX
    Krylon #1818 International Red. You don't need high heat paint.
  16. BackFire
    BackFire Farmall Cub
    Jan 12, 2019
    21
    It may not be exactly IH red but it sure is easy to use and looks great. It's 2k ceramic paint from Eastwood in gloss red. It's a 2 stage paint in a rattle can. There is a small chamber of the hardener inside the can that you puncture with a button on the bottom and shake to mix. Covers alot and only needs one coat. [​IMG][​IMG][​IMG]
    Sent from my Pixel 3 XL using Tapatalk
  17. D. Hinton
    D. Hinton Farmall Cub
    Jan 3, 2017
    53
    Those all look nice. That’s a project I’m scared to do for some reason.
