What oil drain pan can be used on 304 Scout II engine
Discussion in 'General IH Tech' started by sl600, Oct 17, 2019.
  1. sl600
    sl600 Farmall Cub
    Aug 6, 2019
    52
    Looking for a replacement drain pan for my double hump dual drain plug pan on my 73 Scout II does anyone know whether any other aftermarket pans will fit and if yes which one? Trying to avoid paying $350 for an original.
  2. Carl Wiese
    Nov 14, 2001
    8,166
    46
    Oregon City, OR
    There are no aftermarket oil pans. What's wrong with yours? Also, where are you seeing an original for $350? Any SV Scout II pan will work. I had a 392 out of a 74 4x4 pickup and it worked too.
    Sent from my Pixel 2 XL using Tapatalk
  3. scout2000
    4,569
    1,290
    I guarantee that someone here has the oil pan that you need, for significantly less than $350 USD. The BP want ads are probably the best place to start, both to see what is for sale, and to ask if you don't see what you need.
    Where did you find a $350 oil pan? scoutparts.com ?
  4. sl600
    sl600 Farmall Cub
    Aug 6, 2019
    52
    Thanks it was on IHParts NOS but looks like they are sold out.
  5. sl600
    sl600 Farmall Cub
    Aug 6, 2019
    52
    Found one off a later model Scout II but with just the 1 drain plug. Seller states the oil sump is deeper so it may not work but I don't see why that would make a difference. What are your thoughts?
  6. Greg R
    Greg R Dreams of Cub Cadets
    4,974
    665
    A deeper pan needs a deeper oil pickup for the oil pump. I put one on my 800 Scout with no problems as the pan came with the different pickup.
    Look in our vendor's list. From The Scout Connection to Coonrod's; you should be able to find somebody with one.
    sl600 likes this.
  7. winchested
    3,050
    1,084
    All the SV 304 345 pans for SIIs are the same the only difference is the later years got rid of the front plug.
    stroker3 likes this.
  8. Mark Pietz
    Mark Pietz High Wheeler
    May 15, 2003
    1,807
    123
    Foresthill, CA
    Plus, it is easy enough to add the extra front plug if you find a pan without it.
  9. jordandoc
    jordandoc Binder Driver
    Apr 25, 2003
    609
    39
    jordan, mt
    How many do you want? I have some. Call me, I'm in Montana. (406) 557-2819.
