What floor insulation do you use?
Discussion in 'General IH Tech' started by Big Ed, Apr 7, 2020.
  1. Big Ed
    Big Ed High Wheeler
    Sep 29, 2010
    2,529
    433
    Fresno,Ca
  2. Sammy
    Sammy Y-Block King
    Oct 22, 2001
    3,054
    406
    Grigsby's Bluff, TX
    I used lizard skin, heat and sound control with raptor liner on top on the inside and underside. Since this will mostly be an open top, no need for carpet.
    Have duct insulation on the inside of the doors with a R value of 4 and self adhesive, found at Lowe's.
    Have no experience on something else I heard about, Spectrum found on amazon, appears to be similar to lizard skin.
  3. Big Ed
    Big Ed High Wheeler
    Sep 29, 2010
    2,529
    433
    Fresno,Ca
    I hadn’t heard of it, so I had to search. It’s not at all what I’m thinking. I want something you lay in, and can remove if need be.
  4. J.J.
    J.J. Dreams of Cub Cadets
    Dec 14, 2003
    4,781
    2,346
    Castalian Springs, TN
    [​IMG][​IMG][​IMG]
    I just finished with Hushmat. Super easy to roll in. This is my 1st experience with the stuff, Mike Moore of Scoutco recommended it to me, its what they use in all of their builds. I got it 25% off on St Patricks day too, its about $8 sheet. Start at a seam, peel the backing paper off as you go, roll it down. Made in USA.
    JJ in TN
    JJ in TN
    scout2000 and RinTX like this.
  5. kdsmit
    kdsmit Farmall Cub
    Apr 7, 2015
    489
    263
    Delton,MI
    I used the Noico mat, came from Amazon, similar to the Hush mat and installs the same way. It is NOT removable though. I am happy with it! Also used carpet from Stock Interiors, with the Jute back. I am happy with it as well. The jute is a pain to cut though.
  6. Matt O'Bryan
    Matt O'Bryan High Wheeler
    Oct 17, 2001
    1,601
    372
    Wright WY
    What is the material like with that Hushmat? I might have to pull the carpet up on my T'all soon, but I don't want anything that would trap water next to the floorboards.
    Matt
  7. Chris Cooper
    Chris Cooper Binder Driver
    Mar 11, 2018
    678
    246
    Longmont, CO
    I used Dynamat, topped with 1/4” Dynaliner in the foot wells (because my carpet set has 1/4” padding in those areas), and 1/2” Dynaliner elsewhere:
    Still waiting to test the results.
  8. Big Ed
    Big Ed High Wheeler
    Sep 29, 2010
    2,529
    433
    Fresno,Ca
    I found two types.
  9. Big Ed
    Big Ed High Wheeler
    Sep 29, 2010
    2,529
    433
    Fresno,Ca
    I found this one too.
  10. Big Ed
    Big Ed High Wheeler
    Sep 29, 2010
    2,529
    433
    Fresno,Ca
    It would be easier to remove than the spray/brush on stuff, that’s what I meant.
  11. mongocanfly
    mongocanfly High Wheeler
    Nov 5, 2017
    1,723
    1,239
    Alabama
    Just curious..but if you used lizardskin , why would you want to remove it?...I used it inside and underneath my cab...sprays on just like bedliner...I ordered a rubber mat for mine and it can with 2 insulation layers..one is a fiber type, the other is a heavy rubbery tarlike pad...
  12. Big Ed
    Big Ed High Wheeler
    Sep 29, 2010
    2,529
    433
    Fresno,Ca
    I want my truck serviceable.
  13. J.J.
    Dec 14, 2003
    4,781
    2,346
    It’s like a heavy shingle, peel and stick. Press into place and use roller.
    I didn’t want trapped water either, I think it sealed pretty tight but I did spray with raptor under and regular brush on bed liner on the top side first:
    [​IMG][​IMG][​IMG][​IMG]
    Chris Cooper likes this.
  14. Chris Cooper
    Mar 11, 2018
    678
    246
    Longmont, CO
    That's the stuff. I used it so my new A/C doesn't have to work as hard.
    One thing I neglected to take into account is that Dynaliner will change how a carpet set fits. Probably obvious to most of you, but it gained speed as it went over my head. I got lucky, though because the carpet fit perfectly, Dynaliner & all.
  15. kdsmit
    kdsmit Farmall Cub
    Apr 7, 2015
    489
    263
    Delton,MI
    Big Ed likes this.
  16. J.J.
    Dec 14, 2003
    4,781
    2,346
    Hey Ed for what it is worth, in both my 100 and 200 I just used the silver stuff from Lowes. Comes in a roll and is around $30. I did bed line my floors prior to that. Those trucks live inside so I am not worried about water sitting in floor pans. Just trimmed and put on the floor, weight of the carpet or rubber mat in the 200 holding it down and easy to remove if need be.
    JJ in TN
  17. Ron A
    Ron A High Wheeler
    Jan 11, 2003
    1,194
    331
    State of Jefferson
    i used daynamat or something similar in my 61 C10. Only thing I was told when I did it, was to use a butyl based product, and avoid asphalt based.
    J.J. and Big Ed like this.
  18. Binder Brothers
    Binder Brothers Binder Driver
    Apr 25, 2009
    682
    Vienna, VA
    Go to Home Depot or Lowes and get a couple boxes of their water heater wrap. It's basically the same stuff and it works great. Foil backed, self adhesive.
    Big Ed likes this.
  19. Big Ed
    Big Ed High Wheeler
    Sep 29, 2010
    2,529
    433
    Fresno,Ca
    Works pretty good?
  20. Big Ed
    Big Ed High Wheeler
    Sep 29, 2010
    2,529
    433
    Fresno,Ca
    You mean adhesive to stick it on?
