Water tube clamp
Discussion in 'General IH Tech' started by scoutbeck, Aug 25, 2019.
  1. scoutbeck
    scoutbeck Farmall Cub
    Sep 30, 2014
    E Wenatchee
    I am trying to recall where I saw some beefed up water tube clamps recently. Cannot seem to find on any of the vendors' websites. Any ideas?
    Thanks:helpsmilie::stupid:
  2. jeff campbell
    14,808
    1,234
    Maybe same as axle shaft plates ? Tabor ?
  3. winchested
    winchested High Wheeler
    2,885
    975
    Yup Tabor sells them, man I want a set of those axle plates too!
    scoutbeck and jeff campbell like this.
  4. jeff campbell
    14,808
    1,234
    Jim tabor
    scoutbeck likes this.
  5. scoutbeck
    Sep 30, 2014
    E Wenatchee
    Thanks. I saw them on the daughter father build. I may have to look up Mr. Tabor.
    scout2000 and jeff campbell like this.
  6. scout2000
    4,474
    1,211
    Once you get this all figured out, please share (here) whatever direction you went, and also how well it is working for you.
  7. 1975IH200
    1975IH200 High Wheeler
    2,994
    363
  8. scout2000
    4,474
    1,211
    jmait769 likes this.
  9. rustfreeTX
    rustfreeTX Binder Driver
    Apr 5, 2004
    763
    78
    Austin, tx
    re-doing my cooling system right now. What's wrong with the stock ones? Are they prone to break or just don't clamp onto the pipes well enough?
  10. scoutbeck
    Sep 30, 2014
    E Wenatchee
    I will re use the old ones if there is not a more heavy duty option. I had a leak and those things looked kinda scrawny to me, that's all.
  11. jeff campbell
    14,808
    1,234
    They are kinda scrawny but do work.nothing wrong with them. They've been working for 45 years. And will last
    Some people just want stronger LOOKING. Things. O well. Go with what you want. It don't take much to hold them in. And YES when I replace O-rings I DO use silicone on them. Extra added protection.
  12. holyrider
    holyrider Farmall Cub
    May 20, 2013
    261
    Emmett, ID
    Those clamps just hold the tube in the hole. The seal happens at the O-ring. Clean the hole and the tube really well and with slight lubrication at install there should be no leaks. Personally, and I will probably get lambasted for this, but I put a VERY light coating of silicon sealer on mine. Again emphasizing VERY light.
  13. jmait769
    jmait769 High Wheeler
    Jul 15, 2011
    1,373
    625
    Las Cruces, NM
    Used these on the 69, as noted above, and was so impressed I recently ordered two other sets for my other Scouts. The stamped steel OEM clamps are adequate however after being removed and reinstalled several times they can become distorted. In my area with numerous summer days above 100+ degrees I just felt it wasn’t worth the chance to reuse them. The beefed-up clamps do not spread, bend or distort like the OEM ones and can be removed and replaced without worry of deforming. The service manual calls for coating the seal with hydraulic brake fluid I believe to swell the seal. The site is down but Mr. Tabor can be reached at the email stated in the link scout2000 (Thanks Jerry!) posted above.
    HTH
  14. rustfreeTX
    Apr 5, 2004
    763
    78
    Austin, tx
    FYI, that e-mail address got kicked back for me. May try just calling the number.
  15. Mark Pietz
    Mark Pietz High Wheeler
    May 15, 2003
    1,799
    120
    Foresthill, CA
    Ready to be corrected here, but wasn't the use of brake fluid to cause the rubber to swell slightly? I get that, but aren't the newer seals made of a synthetic material that has rendered that step obsolete?
  16. scoutbeck
    Sep 30, 2014
    E Wenatchee
    I called the phone number on the link and talked to John. He operates a bit like we did before amazon/internet took over the world. It was actually pleasant to do it the old way. I ordered and paid for my clamps and they are in the mail. --'Murica!:4x4:
    rustfreeTX and jeff campbell like this.
  17. winchested
    2,885
    975
    Post up his number I want some of those rear end plates.
  18. Patrick Morris
    5,388
    582
    He's around. Working on these clamps as we speak. I was just chatting with him yesterday about this and other subjects.
    Also ask him about the new Scout II radiator support he just developed.
  19. scoutbeck
    Sep 30, 2014
    E Wenatchee
    I believe it is seven seven five 751 0815
    winchested likes this.
  20. Mark Aycock
    Mark Aycock High Wheeler
    Jun 3, 2004
    1,464
    216
    Houston,Texas
    Just out of curiosity, why is Tabor banned from Binderplanet?
