Water Pump Removal 73 Scout II
Discussion in 'General IH Tech' started by sl600, Dec 1, 2019.
  1. sl600
    sl600 Farmall Cub
    Aug 6, 2019
    37
    I have a 73 Scout II without a fan clutch. To remove and replace the water pump I figure I have to:
    1. remove fan shroud
    2. remove the 4 bolts that hold the old water pump
    3. remove the water pump/fan/pulley assembly
    4. swap over the new pump and new gasket
    Am I missing anything or is that pretty much what needs to be done? Thanks for your help out there!
  2. scoutboy74
    6,261
    851
    Drain the coolant. Loosen any belts that engage the WP pully. Once the shroud is separated from the radiator, it can be shoved back onto the engine far enough to gain access to the fan bolts. If clearance is adequate between the radiator and fan, the fan can be removed, which allows easier access to the WP bolts. A piece of cardboard can be used to shield the radiator from damage.
    vince konicki likes this.
  3. mallen
    mallen High Wheeler
    2,704
    490
    Personally, I'd just remove the radiator. Far less agrivation. You have to drain the coolant anyway.
  4. scoutboy74
    6,261
    851
    With the euro-tilt hood, radiator removal becomes it's own aggravation, although not impossible. I'd look it over from both sides and determine if there's enough clearance to do the job with the radiator in place. With the fixed fan, there should be enough.
  5. sl600
    sl600 Farmall Cub
    Aug 6, 2019
    37
    So are you saying that the Fan+pulley+water pump assembly cannot be removed as one unit without removing the radiator and that I would have to remove the fan before I am able to pull out the pulley + WP assembly?
  6. scoutboy74
    6,261
    851
    No. What I'm saying is, if you can get the fan off first, you might want to do that.
    jeff campbell and sl600 like this.
  7. RinTX
    1,789
    468
    I’d try to get the fan off first. Be sure to put cardboard against the radiator and protect it
  8. 1975IH200
    1975IH200 High Wheeler
    2,950
    335
    You will want to break loose the fan retaining bolts prior to loosening the fan belts.
    sl600 likes this.
  9. mallen
    mallen High Wheeler
    2,704
    490
    If the clearance isn't to bad. But beware spending 4 hours wrestling with with a water pump with marginal clearance to save a half hour removing the radiator. Once the radiator is out, your talking literally minutes to swap the water pump without scraped arms or skinned knuckles.
    sl600 likes this.
  10. scoutboy74
    6,261
    851
    Pulling a SII radiator isn't the same as a D-series. The hood is in the way and it doesn't tilt to a 90. You need to have a really good reason to pull a SII radiator and in my experience, a water pump swap isn't reason enough. It can be done with the rad in place.
    vince konicki and sl600 like this.
  11. Patrick Morris
    5,289
    536
    You don't have to completely drain all the coolant. Just take out enough so the level in the radiator is below the WP. And by "take out" I mean siphon the coolant out into a clean 5-gal bucket, using a half-inch length of clear vinyl tubing. This is way less messy that draining out the bottom. And assuming you weren't planning a flush and replacement right now, you can pour that coolant back into the radiator when you're all done.
    I've done the above process many times. The bucket only seems to fill about halfway up. I've changed the radiator doing this and the WP. Good technique also even if you only want to change the thermostat or the heater hoses without making a mess in the engine bay.
  12. sl600
    sl600 Farmall Cub
    Aug 6, 2019
    37
    Did you remove the fan and WP as one assembly or did you remove the fan first?
  13. jeff campbell
    14,502
    1,086
    Fan 1st.
    Patrick Morris likes this.
  14. Patrick Morris
    5,289
    536
    Yeah definitely remove the fan first. It’ll give you a lot more room to work in.
    sl600 likes this.
