Vacuum lines running to the a speedometer cable junction
Discussion in 'General IH Tech' started by Michael1971, Aug 17, 2020.
  1. Michael1971
    Michael1971 Farmall Cub
    Nov 24, 2018
    274
    91
    Can anyone tell me what this box is? The box is marked Holley, and the speedometer cable from the transfer case is going in the bottom, then coming out the top again and into the firewall. There are also two vacuum lines on it, one is coming out of the intake manifold, the other is disconnected from when I swapped carbs out and said " well there are always extra parts". So if anyone can tell me where that line is supposed to call home is, I'd appreciate that as well.
  2. winchested
    3,902
    1,513
    Cruise control I'd assume?
    Michael1971 likes this.
  3. Michael1971
    Nov 24, 2018
    274
    91
    If it is I'd like to know where they're hiding the controls for it! But no, too early of a scout, and it's a manual trans. I see what you mean though.
  4. scoutboy74
    6,729
    1,165
    Deceleration control module. Emissions device. Non-essential.
    jeff campbell and Michael1971 like this.
  5. Michael1971
    Nov 24, 2018
    274
    91
    I didn't know there was any emissions on a 71, so I could just cap off both vacuum lines, I wonder if that would stop the backfiring when I step off the gas at high speeds. Right know my little 100hp 6 cyl sounds like a semi using the engine brakes whenever I let off. Would I be able to hook a speedometer fixer box to it, rather than crawling down and hooking it up to the transfer case?
    https://www.ihpartsamerica.com/stor...jlxsbKE6aZ14gj2wQ9P9MO5I2CbFMcmQaArdOEALw_wcB
