Trying to get correct picture of wiring to 77 345 starter solenoid
Discussion in 'General IH Tech' started by JWolfe, Apr 16, 2019.
  1. JWolfe
    JWolfe Farmall Cub
    Feb 13, 2019
    57
    Dayton, Tx.
    Trying to find diagram for wire up of solenoid on 77 scout 2 345 starter
  2. bull
    bull Binder Driver
    Aug 14, 2010
    865
    124
    some where in the ether
    Have to pull tire off if you need more betterness
    JWolfe likes this.
  3. JWolfe
    JWolfe Farmall Cub
    Feb 13, 2019
    57
    Dayton, Tx.
    Figured that bottle wire and MAIN out but not sure of other two wires
  4. JWolfe
    JWolfe Farmall Cub
    Feb 13, 2019
    57
    Dayton, Tx.
    Bottom wire , but eyelets on other two small wires big enough for MAIN , DO I put them on top small stud anyway or do they go to MAIN also
  5. MrKenmore
    MrKenmore High Wheeler
    2,339
    502
    This is a very original 1978 that has 1979 wiring.
    You have the battery positive, the alternator #2 SENSE wire and the ammeter connection all terminating on the big lug. The little terminal gets the start from the ignition switch. If you have points ignition, you have the other tiny terminal to provide full voltage during cranking to the coil.
    winchested likes this.
  6. JWolfe
    JWolfe Farmall Cub
    Feb 13, 2019
    57
    Dayton, Tx.
    That's the way I have it wired, except I have the gold box, so that other one is xtra, no wires to it,
    Tomorrow I'll check to see if I put the start wire on wrong post, I put on bottom one, maybe I'll try top one tomarrow
  7. MrKenmore
    2,339
    502
    You want the top one for the start from the ignition switch.
    JWolfe likes this.
  8. JWolfe
    JWolfe Farmall Cub
    Feb 13, 2019
    57
    Dayton, Tx.
    Thanks, I'll be on it in morning if no rain
