Towing a 1970 1110
Discussion in 'General IH Tech' started by Afireinside2285, Jul 13, 2020.
  1. Afireinside2285
    Afireinside2285 High Wheeler
    Nov 2, 2003
    1,753
    25
    colorado
    I'm am honestly looking for opinions on the best tow situation. I need to tow a 4x4 1110 pick up roughly 220 miles with posted speed limit between 65-80. Denver to Guernsey Wyoming.
    Currently truck runs and starts. Need tires. I'll take care of that no problem.
    Big question will a u haul trailer carry this thing safely? To be on the safe side it will probably have close to 1000lbs in the bed on the way up?
    Thanks
  2. Darrel
    4,571
    957
    Definitely safe. They use well built trailers. Some issues I've ran into tire ratchet straps too short or not enough space between trailer fenders for oversized tires. IIRC the silver trailers are wider than the orange trailer. But the computer picks the trailer not you. If the u-haul computer rejects your tow rig as being not rated for the load they won't rent to you.
    stroker3 likes this.
  3. Afireinside2285
    Nov 2, 2003
    1,753
    25
    colorado
    Should have added it's a 7.3 ford 4 door.
    Thanks
  4. jeff campbell
    15,456
    1,555
    Tell them your hauling a F-150
    kdsmit, stroker3 and scout2000 like this.
  5. Darrel
    4,571
    957
    Good to go.
  6. Jeff Jamison
    7,631
    1,071
    I hauled my 75 travelall on one last year,about 500 miles round trip,and it wagged the tail a lot if I went over 55,it fit the trailer great.I also hauled my 70 Catalina on one,and I could do 70 without a problem,dont know if it was a trailer problem or the travelall hung over the back to far.Just don't plan on going much over 55
    Darrel likes this.
  7. J.J.
    Dec 14, 2003
    5,197
    2,649
    Castalian Springs, TN
    x2 its an F150.
    I rented them all the time until I bought my own, the uHaul guys knew me and always put F150 on it because "International" was not in the data base. You will be fine with your tow pig, slow and steady wins the race. And like an old trucker told me one time, "if you're worried about your straps you don't have enough"
    JJ in TN
    kdsmit, stroker3 and jeff campbell like this.
  8. kdsmit
    kdsmit Binder Driver
    Apr 7, 2015
    538
    285
    Delton,MI
    Keep the most weight to the front of the trailer.
  9. Darrel
    4,571
    957
    Just checked uhaul.com and they have the 1110 in the database now. Which is good because the ambulance chasers would be all over any deception. Strangely, it also lets you use a tow dolly for the 1110. At least with a 2000 F250 as the tow rig.
  10. Afireinside2285
    Nov 2, 2003
    1,753
    25
    colorado
    Thank you and oddly I do have a 2000 f250 7.3.. I don't think I would chance a dolly though
    Thanks
  11. jeff campbell
    15,456
    1,555
    Dollys work good as long as you use common sense. Towed many vehicles with them. But prefer my 18' trailer.
  12. Afireinside2285
    Nov 2, 2003
    1,753
    25
    colorado
    Yeah probably a trailer lol I
  13. 1210TJ
    1210TJ Farmall Cub
    Feb 6, 2020
    I actually did a test run of trailering my 1210 for the day a couple of weeks ago - I'm on the fence on driving or towing it to the HH. See the attached picture....it barely fit on the U-Haul trailer. The truck is ~4k lbs and the trailer is ~2k and once I played with air pressures in every tire, it motored down the road smoothly. The concern I had was it's too nose heavy on the trailer and I had no way of moving it back. There is a Big Tex trailer dealer in town that offers longer versions to rent, I'm going to test one of those to see if I get a better balance. The VW can max at 7.7k btw so it didn't mind the load.
  14. Jeff Jamison
    7,631
    1,071
    I wouldnt do that,maybe if you had electric brakes on the trailer,but with surge brakes,if it starts swaying you will have problems,and that can very easily push you around in bends.Have you ever towed before
  15. 1210TJ
    1210TJ Farmall Cub
    Feb 6, 2020
    I've personally towed with those u-hauls many times and they are really good trailers that pull straight and true, I just think they are too short for the load in this case, no room for any adjustments on the platform.
  16. Afireinside2285
    Nov 2, 2003
    1,753
    25
    colorado
    What about putting it on in reverse?
  17. mallen
    mallen Y-Block King
    3,470
    838
    Ifg you get a load distributing hitch with a sway damper it takes care of the wagging. Harbor freight sells a good weight distributing hitch. I know, harbor freight has a lot of junk. But Ive seen "name brand" load balancing hitches that are quite obviously the exact same hitch. Its one of those gems. Mine has worked .... without a hitch... pun intended.
  18. David Banner
    David Banner High Wheeler
    Apr 19, 2003
    1,466
    245
    Galloway, OH
    Penske has nice trailers. None of the "strap too short BS" like with some U-haul trailers.
  19. 1210TJ
    1210TJ Farmall Cub
    Feb 6, 2020
    I thought about backing it on but the weight split is pushing 70/30 front to rear, if you draw an imaginary center line, too much of that weight would then be hanging off the end of the trailer up to about the midpoint btw the trailer wheels; too little tongue weight then.
    Darrel likes this.
  20. Darrel
    4,571
    957
    I know U-Haul trailers are designed to not use them in theory, but that's a heck of a lot of weight for that car not having a Equalization hitch. Have you weighed your pick up?
