Tilt column for truck?
Discussion in 'General IH Tech' started by 46binder, Apr 16, 2019 at 10:21 PM.
  1. 46binder
    46binder Binder Driver
    Aug 30, 2009
    606
    Kenosha, Wi
    Can a Chevy tilt column be used in a D series IH?
  2. mallen
    mallen High Wheeler
    1,961
    248
    I used a universal stainless tilt column in mine. It cost 150 off eBay. I had to create a bracket from the old column, and used a flaming river "bowtie" to tie it into the existing lower column.
  3. Darrel
    Darrel Y-Block King
    3,785
    570
    Yes GM can work.
  4. mallen
    mallen High Wheeler
    1,961
    248
    But you will have to improvise on the bracket
  5. Jeff Jamison
    6,664
    507
    There are factory tilt wheels in 74-75.
  6. scoutboy74
    5,703
    578
    What year of truck? Asking because the pre-'74 D's have the IGN in the dash and no steering wheel lock. The tilt columns in '74 and up have the column switch. I only mention it in case the difference is of any concern. If not, then please disregard.
  7. 46binder
    Aug 30, 2009
    606
    Kenosha, Wi
    I believe I have a Chevy tilt, but I have a manual transmission in the truck
  8. Darrel
    Darrel Y-Block King
    3,785
    570
    Is that supposed to be a question.
  9. scoutboy74
    5,703
    578
    What we've got here, is failure to communicate. Some men you just can't reach.
    Darrel likes this.
  10. 46binder
    Aug 30, 2009
    606
    Kenosha, Wi
    No, just saying I have a Chevy tilt I could use but I’m almost positive it’s got a shifter, so unless I find a 74-75 IH one, a non shift tilt will be a pita to find, or get an aftermarket one. Totally forgot about the shift problem when I asked about a tilt column. And I also have a dash ignition, so that’s another problem. Non tilt it is then.
  11. jeff campbell
    13,387
    720
    Right on. My favorite. Cool hand Luke !
  12. scoutboy74
    5,703
    578
    The column key tumbler can be removed or otherwise defeated to render the wheel lock inactive and you don't have to use the column ignition switch, but if looks are important, that might not be the best route.
  13. mallen
    mallen High Wheeler
    1,961
    248
    The aftermarkets are pretty much the same as the GM ones, except you need to do something about the mounting bracket.
