Thoughts on preserving a windshield frame.
Discussion in 'General IH Tech' started by rustfreeTX, Jul 11, 2018.
  1. rustfreeTX
    rustfreeTX Binder Driver
    Apr 5, 2004
    804
    91
    Austin, tx
    My current windshield frame has some pretty bad rot on the under side and small rust holes on the top. I scored a solid frame years ago, it only had one spot of surface rust on the lip under the seal(glass is out), but when you move it around you can hear rust flakes, a few even drop out from the bottom. So, I know it's rusting from the inside and want to slow or stop that as much as possible. I don't think filling the hollow channels would be a good solution, but maybe spraying either naval jelly or POR-15 in there might help? Anyone tried this or have any other suggestions? I'm getting to the point where I may actually paint it, put in some glass and install.
  2. 1975IH200
    1975IH200 Y-Block King
    3,392
    629
    If it were mine, I would put about a quart of Black Bear brand Par-Al-Ketone inside it and maneuver it to allow full coverage, then drain excess.
  3. Mark Aycock
    Mark Aycock High Wheeler
    Jun 3, 2004
    1,555
    259
    Houston,Texas
    Thank you.
  4. Johnnycobra
    Johnnycobra Farmall Cub
    Nov 20, 2011
    452
    27
    Austin, TX
    I thought about using ospho poured into one, flushed and then after drying a few days, using something like POR15 or something like that par-al-ketone.
    blue smoke likes this.
  5. RinTX
    2,667
    1,030
    That par-al-ketone sounds pretty interesting. Another possibility is a two part epoxy or two part bedliner/urethane poured in and sloshed around - like they do to line the inside of an old gas tank.
  6. MrWolf
    MrWolf Farmall Cub
    Jul 18, 2011
    274
    17
    Norway
    Anyone tried out Fluid Film?
    It's very popular over here in Norway with damp and salty conditions. Used for undercoating and is supposed to stop already formed rust, so should be ideal.
    I did some googling and ended up buying some of their products... :)
  7. rustfreeTX
    Apr 5, 2004
    804
    91
    Austin, tx
    Thanks all for the suggestions. As we all know, a good windshield frame is pretty much un-obtain-iam these days, so I want to try and keep this one in the best shape possible.
  8. Patrick Morris
    6,295
    936
    I would dissolve the internal rust first, before trying to spray anything in there. See this post of mine about how I used a product called Evaporust to make the internal rust (mostly) disappear. The stuff is amazing. It litterally dissolves rust. Turns it to a black muck that wipes/washes off. None of this "conversion" BS:
    http://www.binderplanet.com/forums/index.php?threads/tailgate-hinge-tube.136803/#post-1016206
    You can kinda see from the pic in that post that I had to apply some ingenuity to immerse (this process requires immersion) one section of the WSF at a time: top, then each side/A-pillar. hanging it from a rafter in those orientations. Three day's soak per side. This way I was able to do it by just starting with 3-4 gallons of the stuff. BTW, it's reusable. When I was done with this job I put it back in its jugs and use it for other jobs from time to time.
    FWIW, the top section of my WSF here actually was pretty much rust free already. I just did this as a precaution. Most rust happens in the lower 25% of the frame, inside the cowling and corner areas.
  9. Patrick Morris
    6,295
    936
    Oh, and if you have a way of spraying in POR15 then go for it. It'll be hard to know if you're getting complete coverage though. My cowl section was removed and so I was able to just brush on POR15 where it was needed and where the rust forms the fastest. For the A-pillars and top rail I sprayed in some black waxy stuff that I got from Eastwood.
    And remember that moisture flow downward and collects at the bottom. Couple of small drain holes drilled at those spots wouldn't be a bad idea. Drill them first so they'll give you some good angles to shoot in your coating, whatever that ends up being.
  10. rustfreeTX
    Apr 5, 2004
    804
    91
    Austin, tx
    Wow, that's pretty detailed. How were you able to see inside the frame, bore-scope? I haven't really taken a close look yet, but I seem to remember seeing a couple of small access holes on the bottom, so did you drill those out more or make different access holes? That dipping system was pretty inventive.
  11. Darrel
    4,994
    1,157
    Have you checked with any stripping/coating shops? They can get every internal nook and cranny like you wouldn't believe. This is simplifying, but they strip to bare metal with a chemical bath process (phosphoric acid, caustic soda, electrolysis, baking) then they electrically apply a bare metal coating followed by zinc. I don't know what the price is for just a windshield frame, but when I checked into this a few years back my quotes were $7-1500 for an entire car.
  12. Dennis Bernth
    5,968
    41
    Mill Creek, IN.
  13. Patrick Morris
    6,295
    936
