The "Revenant" (a Champagne Scout).
Discussion in 'Binder Builds' started by Scat_bucket, Feb 23, 2016.
  1. Scat_bucket
    Scat_bucket Farmall Cub
    May 9, 2013
    182
    Salt Lake City, UTah
    IMAG1352.jpg IMAG1342.jpg IMAG1343.jpg I accidentally bought this '65 Champagne Scout last Spring.
    I wasn't in the market for another one, but this was for sale not far from my house and I thought it wouldn't hurt to just look at it (haha, wrong!). It wasn't running and I really didn't have room for it. So, I thought the best course of action would be to offer a low price that the owner would refuse. So I offered less than a third of his asking price. He said "absolutely not!", turned his back and walked away, leaving me standing in the street. I dodged that bullet, so I thought... Half an hour later he texted me and said that he would take my offer. At that point I felt obligated to follow through. After a few hours I got it started and I drove it home with the rear left wheel wobbling, and leaving a trail of oil for three miles leading up to my driveway.
    The good news is... after some research that I realized that I bought a Champagne Scout. My plans are to restore it to original as my finances and time permit.
  2. Scat_bucket
    May 9, 2013
    182
    This is why the left rear wheel wobbles: IMAG1398.jpg
  3. Scat_bucket
    May 9, 2013
    182
    I'm not sure if the back seat is from a '65. The color is redish-brown. Does anyone know which years this style of arm rests were used?
  4. customtronic
    customtronic Farmall Cub
    Nov 15, 2011
    446
    56
    Olympia, WA
    Awesome find!!!! Congrats!
  5. Jeff Jamison
    5,782
    177
    That's definatly not the correct color on the rear seat,but the seat is correct style,dont know on the arm rests.
  6. Scat_bucket
    May 9, 2013
    182
    Thanks customtronic. I'm not sure if I'm lucky or not. Definitely overwhelmed. Having two Scout projects is a lot.
    On the arm rests, I have seen two types: the padded ones, and the one piece hard plastic ones. I don't know when each type was used.
  7. Champagne Scout
    Champagne Scout Farmall Cub
    Oct 4, 2014
    86
    Detroit, MI/Madison, WI
    Glad to see you decided to restore it! Good luck with the build!
    -Champagne Scout
  8. Scat_bucket
    May 9, 2013
    182
    Thanks Champagne Scout! I might be keeping this '65 CS because it doesn't require emissions testing in Utah. My 800 B does, and it failed last year (PITA may sell it). I will be cross checking your thread.
  9. Scat_bucket
    May 9, 2013
    182
    I agree, Jeff. Its the wrong seat. I got rid of it and found a Champagne colored one.
  10. Scat_bucket
    May 9, 2013
    182
    The rear main seal is leaking a lot. About a cup of oil every 5-minutes of running time. Gotta pull the tranny to fix that. Here's some pictures of the transmission coming out.
    I decided to remove the trans by turning it 180 degrees and lifting it with a transmission jack up inside of the Scout. trans1.jpg
    From the inside I hefted it over to the passenger area.
    And then from the outside I hefted it back onto the transmission jack which was a convenient way to wheel the trans around without messing my back up. It may have been easier to remove the shift tower and wheel the tranny out from below. Maybe next time.. trans 2.jpg
    After I scraped it with a putty knife I pressure washed it twice, used a couple cans of engine cleaner, a can of oven cleaner (good for cast iron, but keep it away from aluminum), scrubbed it with Pinesol, and wire brushed it. Not an easy cleanup!
  11. Scat_bucket
    May 9, 2013
    182
    I found several problems when I removed the transmission. First, I found that the pilot bearing was broken. pilot.jpg
    That could be the source of the shrieking noise I heard when the engine was running. Easy fix, this part is available at the auto parts store.
    Second I found a dent in the bowl shaped sheet-metal cover that allows access to the clutch from underneath the truck.
    When I looked inside it was clear that the flywheel was rubbing where the sheet metal was dented. This could also be the source of the shrieking noise when the engine was running. Clutch Access piece 2.jpg
    Easy fix, I pounded it out with a hammer.
    Third, I noticed that the transmission support was bent. Someone probably hit a big rock.
    The bent support (and loose bell housing bolts!) probably caused a misalignment with the engine, which destroyed the pilot bearing, which may explain why the transmission won't stay in second gear (so I have read). The fix on this has not been so easy. I put the support on a press and almost have it straight. It still needs a little more fixing.
  12. Scat_bucket
    May 9, 2013
    182
    It was my plan to just freshen up the transmission seals. Then I heard a sickening noise as I was separating my transfer case from the transmission... the tinkle of bearings getting loose and falling to the bottom of the transmission. Ooops! I should have taken the shift tower off first and tied the main shaft in place so that it couldn't slide out and release the bearings :-(
    Lesson learned. Time for a pause to think about how far I want to go with a rebuild.
  13. Top Ramen
    Top Ramen Farmall Cub
    Mar 26, 2016
    102
    22
    Something about one step forward and two steps back comes to mind.
    It sounds like this vehicle found the right person. All too many of these beasts are being parted to make one from two.
  14. Scat_bucket
    May 9, 2013
    182
    Project Update: I found a new transmission. The CS Scout is hybernating now. The install will have to wait until the spring thaw. unnamedsnow.jpg .
  15. Scat_bucket
    May 9, 2013
    182
    Spring became summer before I got back to the CS Scout.
  16. Scat_bucket
    May 9, 2013
    182
    rear seal 2.jpg Pulled the leaky Rear Main seal using three screws and a slide hammer.
  17. Scat_bucket
    May 9, 2013
    182
  18. Scat_bucket
    May 9, 2013
    182
    Freshened up the seals and painted everything with epoxy.
  19. Scat_bucket
    May 9, 2013
    182
