SV8 front dipstick tube seal
Discussion in 'General IH Tech' started by jtorre4272, Oct 9, 2019.
  1. jtorre4272
    jtorre4272 High Wheeler
    Nov 19, 2014
    1,639
    575
    Dearborn, MI
    Looking for a seal for the front block dipstick tube receptacle in my 392. Trucks used the front receptacle. Scouts used one in the oil pan. Therefore I need to plug the hole. My engine had no seal.
    One of our awesome lightline vendors offered to send me one from a used block but I’d rather avoid putting him through the trouble if I can.
    Came across this gadget. Designed for a GM LS.
    Anyone know if the diameter will work? Can’t measure an IH dipstick at the moment. Nor do I know the diameter of an LS dipstick tube.
  2. Jeff Jamison
    7,011
    685
    Iam glad you know where the leak is now.I have no idea of the size.
  3. winchested
    winchested High Wheeler
    2,566
    813
    Pretty sure its 3/8" . I made my own did stick tube out of stainless.
    jtorre4272 likes this.
  4. jeff campbell
    14,290
    997
    Just use a butt plug joe !
  5. Dana Strong
    4,825
    957
    Don't you have access to a lathe? If so, taper turn a short piece of brass after measuring the hole yourself, leaving enough on top that you can grab it with a Vice-Grip if you ever need to remove it. Polish well before installing, of course. :beer:
  6. jtorre4272
    Nov 19, 2014
    1,639
    575
    Dearborn, MI
    Appreciate your encouragement Dana, but At $14.99 with an o ring, it’s simply not worth my time to fabricate anything if this works.
  7. mjmck
    mjmck Farmall Cub
    Oct 4, 2019
    45
    19
    Manlius, NY
    What I have done in the past on mustangs is use tiny little brass freeze plugs. When you do a 351w swap the stick enters the side of the pan not through the block anymore. Just another avenue for you.
  8. timetraveler77
    timetraveler77 Farmall Cub
    Jan 28, 2017
    161
    57
    SW OH
    I had the same issue w my 392, couldn't figure out oil leak then it dawned on me about front tube hole. I was going to get a plug from SSS or a small brass plug but I used a dip-tube for a sm blk chev off ebay ($11) Tube.jpg & cut it to measure oil in front sump. Looks good & functional
  9. jeff campbell
    14,290
    997
    Go to parts store & look in the Dorman drawers.put a freeze plug in it.
  10. jtorre4272
    Nov 19, 2014
    1,639
    575
    Dearborn, MI
    This is a great backup idea. Thanks!
