Super Swampers on a dually
Discussion in 'The Truck Stop' started by Beachead, Dec 25, 2015.
  1. Beachead
    Beachead Farmall Cub
    Aug 3, 2014
    76
    Delaware
    I have always liked the look of a dually 4x4 with some aggressive, big lugged tires on them.
    Since I have obtained my new Frankenstein 1510 4x4, I've been looking at the narrower Super Swampers, such as the 34x10.50-17 LTB or 33x9.50-17 SX tires. I need to ditch the 17.5" rims that are on it currently and step down to a 17, which looks like would fit. Probably a 17x7 or 17x8.
    I have a lot of experience with Swampers on my Jeeps over the years but never on a big truck or dually.
    My questions are:
    Will I still be able to retain some, or most of the trucks carrying capacity with a tire like that?
    These SS tires are bias 8 or 10 ply. Is that enough? I need to see what load range options they come in.
    Anyone have any experience with putting that type of tire on a dually, any safety concerns in doing so?
    I definitely need to put new tires on it and want the nasty tires, but want it to be done right.
    Thanks
  2. Beachead
    Aug 3, 2014
    76
    Delaware
    So I ended up getting the E rated Super Swamper sxIIs in 33x9.50-17. I found GM 17x6.5" 8 on 6.5 new steel wheels to use with the tires. Here is a pic of what it will kinda look like.
  3. BO185
    BO185 Y-Block King
    Jun 8, 2004
    3,452
    193
    Jacksonville, Arkansas
    Measure the hub opening on the GM wheels. I know they will not fit the 1210 3/4 ton axle hubs. Most guys use Dodge or Ford rims because of this. I would make sure rims fit over hubs before spending money to have them mounted.
  4. Beachead
    Aug 3, 2014
    76
    Delaware
    The truck has GM 8 lug wheels on it already, I did measure the hubs, looks to be all good. I still have to order the wheels yet.
    As to why it has the 8 lug axles on it, I'm not sure yet, old owner may have swapped the hubs/brakes when he put the GM hydro boost setup on? The front is closed knuckle D70F and rear is an Eaton.
  5. BO185
    BO185 Y-Block King
    Jun 8, 2004
    3,452
    193
    Someone swap'ed in 1310 (1 ton axles) I bet. They used 8 lug Dana 70 front (6k rated) and rear IH corp RA 15 8 lugs. I believe the 1500 had the RA20. So not actually not an Eaton axle should be IH corp. The RA15 was rated 7,500 # and the RA20 was 10k. I would have to find the spec sheets, but that's what I remember them being. Either way good thing is they are 8 lug and easy to find wheels for.
  6. Beachead
    Aug 3, 2014
    76
    Delaware
    That could be, I am not too familiar with these trucks yet....not too much out there it seems. Thanks for the info. Here is pic of rear axle.
  7. BO185
    BO185 Y-Block King
    Jun 8, 2004
    3,452
    193
    WOW a rear sway bar that's interesting. Not sure that is factory, as it looks like the arms aren't level . Interesting.
  8. DNL
    DNL Binder Driver
    869
    Hazen, ND
    Gonna look great with those tires.
  9. Beachead
    Aug 3, 2014
    76
    Delaware
    Yeah, a sway bar in the rear, kinda odd . Might help with a load on back??
    Thanks DNL
    Can't wait to get tires on there.....still need to order wheels and nuts. Too cold here to mess around with the truck too much anyway.
  10. PlanetMan
    PlanetMan Farmall Cub
    Jan 17, 2017
    Nice choice on the super swamper. have you managed to put those on your truck?
  11. rotak
    rotak Farmall Cub
    Oct 5, 2017
    22
    NICE! Those are gonna look awesome. Almost makes me jealous that my R162 rolls on medium-duty rubber only--no SS for me!
  12. Beachead
    Aug 3, 2014
    76
    Delaware
  13. Beachead
    Aug 3, 2014
    76
    Delaware
  14. rotak
    rotak Farmall Cub
    Oct 5, 2017
    22
    Now THAT is an offroader!
    Beachead likes this.
  15. Beachead
    Aug 3, 2014
    76
    Delaware
  16. 74binder
    74binder Binder Driver
    Apr 26, 2002
    543
    74
    Bradyville, Tennessee
    Those look like Dodge Ram 3500 wheels.
  17. DNL
    DNL Binder Driver
    869
    Hazen, ND
    That is a good looking truck.
