"START HERE"--Fuel Injection FAQ--"START HERE"
Discussion in 'Injection Tech' started by Bill USN-1, Dec 29, 2005.
Thread Status:
Not open for further replies.
  1. Bill USN-1
    17,136
    296
    To keep stickys to a minimum, I will try to keep the most important threads linked from here.
    First, all information is free but this web site isn't.
    So as you sift thru all I have posted here, if you feel it has helped or saved you some time or money...please consider becoming a member.
    Then head to the online store and drop a few coins to help support our efforts.
    Before you start here is a little introduction Video for your enjoyment.
    The most important question is:
    What system do I want?
    GM Based system.
    First came ECMs-Engine control management-
    Then PCMs-Powertrain(eng/tran) control management-
    These allow full control of engine and electronic transmissions. They can be MPFI-multiport, SFI-sequentialport, CPI-centralport or TBI-Throttlebody fuel injection.
    TBI
    What parts do I need?
    What Throttle Body adapter do I need?
    454 factory adapter cautions
    MPFI-- Multiport fuel injection
    MPFI discussion
    1227730 install
    Option 1-Modifying the TBI/CPI 16168625/16197427/16196395/16156930/16245358 PCM for MPFI.
    First install-Batch fire with 7427 PCM
    MPFI Manifolds
    Drilling an IH Only aluminum manifold
    Drilling a stock 345/392 cast manifold
    Installing the manifold
    Then we need to be able to wire all these parts up so:
    What wires do I need to use for the 1227747 ECM?
    How about the later TBI PCM 16168625/16197427/16196395/16156930/16245358 PCM
    IH Holley Distributor stock specs and rebuild.
    And then.... what distributor can I use? (for FI and carbs) NO- your pertronix will not work for the EFI conversion
    Duraspark conversion using a Holley distr for carbs and EFI-Saves you $500 for HEI
    Duraspark conversion option 2
    Mopar conversion using the Holley Distr
    Prestolite-Mopar EFI conversion
    GM/IH Hybrid
    DUI/large cap HEI/Stock conversion
    Duraspark conversion using a Prestolite dist
    HEI for the IH 6 cyl
    Stock IH/Chevy Stovebolt 6 cyl Delco distr conversion
    AMC V8 Duraspark Distributor
    AMC 258 6 cyl Duraspark distr for carb and EFI
    IH MV series distributor conversion
    Once the initial installation is done then you need to perform these
    initial setup procedures.
    I built the Distributor, so what do I hook it to? (Ignition upgrades for FI and carbs)
    Ignition Systems
    FUEL SYSTEMS
    In Tank Pumps
    Dual Tanks
    How about Dual Fuel options
    304 Dual fuel conversion
    What about those aftermarket Systems?
    MSD Atomic TBI
    FITech
    Holley Distributor Phasing
    MISC
    Can you walk me through a fuel injection conversion step by step? Thread in progress!!
    What about Fuel Injection on a 4 cyl?
    Another 4 cyl TBIOnly this one has DIS- distributorless ignition
    4 Cyl MPFI- Just cause we can!
    TBI for the inline 6cyl crowd
    How do I remove Injectors or make my Fuel Pressure Regulator adjustable?
    Vacuum fuel pressure regulator conversion for TBI
    What VSS can I use?
    Hot Fuel Module-What is it?
    Basic Trouble Shooting
    TUNING AND PROGRAMMING CHIPS
    How to remove the chip from the plastic carrier....Video!
    Chip Programming options
    How do I get the data out of the computer and then change it?
    Basic chip adjustments
    Basic timing table
    How do I install the Moates EEPROM adapter?
    How to convert from the 2732 EPROM to a 27SF512 EEPROM
    LINKS
    Where else can I go to get more information and reference material?
    What if I still have questions because you didn't do a very good job of explaining it?
    Take a look at this Video, it may help! :)
Thread Status:
