spraying lizard skin?
Discussion in 'General IH Tech' started by Will Courtney, Mar 19, 2010.
  1. Will Courtney
    Will Courtney Farmall Cub
    Sep 7, 2008
    293
    Bassfield, MS
    Been looking at lizard skin as suggested by a forum memeber. Looks like good stuf, but can anybody recomend a cheap spray gun for it? Don't want to spend the money on a high end gun to use just once.
    Will a normal auto spray gun work to spray it? I do have access to an airless spray gun, will this work?
    Going on a fiberglass tub and steel front fenders and doors and hood.
    Thanks.
  2. IHWILD
    IHWILD High Wheeler
    Feb 17, 2002
    1,135
    Windham, ME
    I think it is thicker closer to but not quite undercoating then paint. Not sure is paint guns would work but maybe with a bigger tip. Try to look for a picture of their gun and compare nozzle style and size.
    Hth
    Rich
  3. Will Courtney
    Sep 7, 2008
    293
    Bassfield, MS
    thanks, I know they recomend spraying, but not sure of the viscosity of it. Well, not ready for it yet, maybe do a little more research and see what they recomend for a sprayer.
  4. surfnturf
    surfnturf Binder Driver
    Oct 9, 2007
    797
    Cowpens SC
    I haven't tried it but I think a shutz gun would work. I have heard of people using it to spay Hurculiner.
  5. TheDon
    TheDon Binder Driver
    Jul 3, 2007
    573
    Raleigh, NC
    FWIW, This stuff was recommended to me by a fellow IH guy, one who is pretty thorough in his research. It's supposedly pretty close to Lizardskin but $50/gal rather than Lizardskin's $80/gal. Even if it's not quite as good, I can live with it considering the cost savings. The customer service was pretty good, and it arrived in a timely fashion.
    My Traveler is in the middle of its frame-off, so I can't give you an opinion of its performance just yet.
    http://www.edesignaudio.com/product_info.php?cPath=1_24&products_id=53
  6. Will Courtney
    Sep 7, 2008
    293
    Bassfield, MS
    Sounds like good stuff.
    Can you apply lizard skin, or E-block or any of the other coatings with just a roller and brush, or does it have to be sprayed?
    Thanks
  7. raleighrugger
    raleighrugger Farmall Cub
    Jul 24, 2009
    208
    Raleigh, NC
    I used this product http://www.fatmat.com/liquid/gallon.html over two coats of MasterSeries Silver Permanent Rust Sealer/Surfacer. It went on real easy using a roller and brush. The nice part about this stuff is it goes on blue and dries black to ensure good coverage. I picked it up on eBay from the manufacturer for under $50. It goes a long way!
  8. Will Courtney
    Sep 7, 2008
    293
    Bassfield, MS
    I like the looks of this product, will do a little reading, sounds like what I'm looking for. I want to seal the raw glass and sound proff the front fenders and such. Want a decent heat shield for the motor firewall and for the tail pipes as well.
    Thanks.
  9. raleighrugger
    Jul 24, 2009
    208
    Raleigh, NC
    If you want, I can put a little bit in a jar or pint paint can and mail it to you so you can try it out.
  10. Will Courtney
    Sep 7, 2008
    293
    Bassfield, MS
    Thanks, I apreciate it, but don't worry about it. It sounds like it'd work perfect. Just need something to seal the raw fiberglass and act as a heat shield.
    Thanks,
    Will
  11. john howard
    john howard Farmall Cub
    Jan 5, 2018
    Thank you the above information is really helpful to me i am also looking for a best quality paint sprayer for my home use please do suggest me some products by good brands. thanks in advance.
  12. gillis51
    gillis51 Binder Driver
    Feb 3, 2010
    617
    99
    Easton, MA
    I used lizard skin ceramic heat control on the inside tub of my 800. Used a harbor freight undercoat gun and it worked fine. Just need to clean between uses. Need to transfer the paint to a bottle that will fit your undercoat gun. I found that a 1qt? Gator aid bottle fits ok.
  13. Bryan Boretsky
    Bryan Boretsky Farmall Cub
    Feb 1, 2018
    49
    20
    Lolo MT
    UPOL mkaes a gun for Lizard Skin.about 15 -20 bucks. Designed for Lizardskin.
  14. gillis51
    Feb 3, 2010
    617
    99
    Easton, MA
    U Pols gun is an undercoat gun exact same as harbor freights.
    I used both to spray the lizard skin and the texture is exactly th same between the two guns.
    The only people who make a specific gun for Lizard Skin is the people at Lizard Skin. I haven’t seen the texture from lizard skins gun but know that the harbor freight / u pol gun got the job done and it looks perfect. Uniform thickness as well.
  15. mongocanfly
    mongocanfly Farmall Cub
    Nov 5, 2017
    444
    207
    Alabama
    wish I had known that [upol] before I bought the lizard gun..haha
  16. Bryan Boretsky
    Feb 1, 2018
    49
    20
    Lolo MT
    I was wrong.I have the Raptor Liner. sprayed with the Upol gun, looks great and gun was easy to clean.
