Sound Deadener on bed liner???
Discussion in 'General IH Tech' started by Brandonium, Sep 30, 2007.
  1. Brandonium
    Brandonium Binder Driver
    May 11, 2004
    556
    Helena, AL.
    Hey all,
    I am ordering my carpet tonight or tomorrow and was also looking at purchasing some sound deadener to cut down on sound and heat. I am adding the mass backing option to the carpet but I'm not sure if that is enough to kill the heat and noise. My floor has a bed liner so I was curious if there would be any potential problems from attempting to attach sound deadener to it. Any thoughts or concerns?
    Thanks,
    Brandon
  2. Doc Stewart
    49
    Wipe the bead liner with acetone lightly. Glue the sound deadener down.
  3. scoutman800
    scoutman800 Y-Block King
    3,530
    salem, ohio
    when you say sound deadener do you mean like dynomat? my bedliner is rough texture and i'm sure it would work, but the bedliner knocked my heat and noise way down by itself. carpet would really do it. i'd think about running a few screws in here and there where it's gonna be stressed the most.
  4. Brandonium
    May 11, 2004
    556
    Helena, AL.
    My bed liner isn't super rough but it isn't completely smooth either. I would say maybe half/half. I was looking at a product similar to dynomat. I ordered carpet from ACC with mass backing also. I just know that when I drove it last month for an hour that the floor cooked the crapola out of my sandals. SUPER HOT! I don't want that to happen again, especially with carpet. lol
  5. Hutch
    Hutch Farmall Cub
    Jan 15, 2004
    343
    AZ/Wyoming
    Check Out these guys, they have a lot of good info in their forums and seem to answer question quickly:
    http://www.secondskinaudio.com/store.php?category=70
    I would think it would stick fine to the bed liner.
    A cheap alternative, though maybe not as effective is using a roofing underlayment like GRACE ice shield (sometimes called b**chathane in the building circles) which you can get at Home Depot or Lowes, any Butyl underlayment would help some. Though the high end guys like Second Skin say it's not the same.
  6. Brandonium
    May 11, 2004
    556
    Helena, AL.
    That is exactly the material I was looking at. Sometimes I feel like it's a gamble, especially with the price most sound deadening runs. Still less costly than dynamat... :)
  7. thedutchtouch
    thedutchtouch Farmall Cub
    Oct 12, 2006
    164
    Pittsburgh, PA
    depending on my home engineered you want it to be, regular housing shingles are the same material as sound deadener. it's getting it to stick that's sole work, like epoxy or something.
  8. IH64Scout
    Apr 13, 2004
    4,683
    Jessup,PA
    to quiet the 6.9... ;) ....i sprayed the engine bay w/ 3M undercoat and dynamatted the firewall back under the floor (above trans. t/c). i'm going to pull the dash and 3M spray behind it and dynamat, then reinstall the dash and have something to the lines of rhino lining sprayed in the cab/bed. then i'm going to dynamat (i know $90 a box is alot but i'm not holding back now!) the floor inside the cab and use some style of marine/water-resistant (quick evap.) carpeting. with all luck that'll make the 6.9 cackle bearable and remove enough road noise and heat to make all day cruising EVEN MORE pleasureable then JUST being in a scout!! ;) :wub: :clap: :yes:
    and as long as the liner is stuck good the deader will stick great, dynamat is like ROAD TAR, so it probably won't ever come off w/out a fight! :p
    -Jon
