SOA Ubolt question
Discussion in 'General IH Tech' started by codeman, May 30, 2020.
  1. codeman
    codeman Farmall Cub
    Dec 23, 2010
    205
    35
    hebron, MD
    74E0D90B-B2D1-403C-AC84-88AFBA1F7FD3.jpeg 6F913CCD-B94E-407A-9FE0-08D2256BF02E.jpeg D8AB400B-F70A-4F53-9F7F-204D7F67BAAC.jpeg I’ve searched and asked without much success. I haven’t seen a good solution to fitting the ubolts under the differential casting. I’m going to Mill a section of 4” OD thick wall tubing to fit and get good bearing/welding area. Just so happens a coffee can was the perfect pattern material. Looking for feedback. TIA
  2. Justutt67
    Justutt67 Farmall Cub
    Feb 16, 2013
    333
    143
    Broomfield, CO
    I am confused about what you are trying to accomplish. My U-bolts fit perfectly. Did you order the wrong size?
    B81C3DCF-C1FD-4D27-9748-924B7BC09A14.jpeg D8921BA6-D9D2-4F01-A717-DDFC2F766F36.jpeg 6F5A8BB3-9E06-4E4D-AADC-564531D0698A.jpeg
  3. Darrel
    4,999
    1,160
    Yeah, DOM is fine but not the easiest path. If you're concerned about losing housing strength you could build up that flat area next to the old perch with weld before shaping it with a die grinder. Really though I don't think you lose too much by cutting a ubolt groove. I would recommend tying your new perch into the side of the pumpkin though.
    tinker likes this.
  4. WRENCH MAN
    Dec 24, 2004
    4,349
    152
    Eugene Orygun
    I would have narrowed and done a "cut and turn" on a Chevy housing before I spent a minuet screwing with the Scout housing.
    Darrel likes this.
  5. codeman
    codeman Farmall Cub
    Dec 23, 2010
    205
    35
    hebron, MD
    Thanks guys! I tend to overthink things. I didn’t think about just making the ubolts fit.
  6. codeman
    codeman Farmall Cub
    Dec 23, 2010
    205
    35
    hebron, MD
    Thanks for the suggestion, but don’t have the skills for that.
  7. codeman
    codeman Farmall Cub
    Dec 23, 2010
    205
    35
    hebron, MD
    I’m planning on welding the perch to the housing. It’s just tacked now for mock up.
  8. Darrel
    4,999
    1,160
    Chevy housing is easy. Basically remove the yokes, cut the tubes to Scout length, weld the yokes back on, bolt your parts back on. Only extra step over a cut and turn is cutting down the tubes. End result is stronger. Stronger housing housing. Stronger tubes.
    I know. Not sure if I was clear. When you cut/notch the housing for the perch it becomes rather weak. Fix is to weld/gusset the top edge of the perch to the side of the housing up high so everything is tied together.
