SOA lift & Tire size
Discussion in 'General IH Tech' started by Hoss Scout, Sep 12, 2011.
  1. Hoss Scout
    Hoss Scout Farmall Cub
    Jul 27, 2011
    58
    Boyne City
    After some research and help from you guys on here, i'm gona get roughly about 5" of lift. On my 1970 800a scout. What size tire can i fit under there now?
    Now with only having a 196ci and 4.27:1 gears it still like it to be able to get out of it's own way. So maybe 33" or 35"? Maybe 35" are little big and a Dana 27 killer...just looking for some input from people that have done SOA!! It's not gonna see much off road! :beer:
  2. Mark Ashford
    Jan 30, 2002
    3,989
    Woodinville, Wa
    800's are a little different as they have different shaped wheel wells... but for comparison on a Scout II, a typical SOA nets you around 5.5 - 6" of lift.
    You can make 32's rub if you try hard. 33's can clear pretty well with a little minor fender trip and cleanup, 35's will rub unless you cut or bump stop or lift more (body, shackle etc) or a combo of all the above.
    Physicaly fit... I' bet 35's will look good on it, but you'll need to take provision to keep the tires out of the body.
    *I* wouldn't waste my time and effort on the stock axles. Start with a set of Scout II D44, Waggy D44's or a Chevy D44 and work from there. I'd also look at a spring swap to get something a little more over-all durable than the stock 1.75" wide springs.
    Plan on driveshaft upgrades/rework, steering upgrades and conversion (powersteering, new tie-rod/draglink and highsteer or Z-link), brake upgrades (discs, power or manual), Shocks, Brake Lines, gearing, motor upgrades.... the list is endless.
    Oh, and if you don't have it yet... CAGE and better seatbelts.
  3. Hoss Scout
    Jul 27, 2011
    58
    Boyne City
  4. Mark Ashford
    Jan 30, 2002
    3,989
    Woodinville, Wa
    ummm, think again. Search around, some of the nastiest wrecks and squished top are from road acidents. Lift a Scout and the potential can get even worce.
    Put a 4-point bar in there if there is not already one. It WILL save your life.
  5. Tom Mandera
    Oct 19, 2001
    4,207
    Helena, MT
    I concur.
    The disc brake Dana 27 will be fine for street service, but of the various rolls and wrecks I've seen, the ones on the trail are pretty boring, but the ones on the street are horrific.
  6. Hoss Scout
    Jul 27, 2011
    58
    Boyne City
    Well no one has really answered my tire fit question yet!!!!! :confused:
  7. db1115
    db1115 High Wheeler
    Jul 2, 2007
    1,653
    65
    Tyler, TX
    I would say 33s max if it wont be seeing any off road driving. Even that might be too much for the d27 if its not in good working order.
  8. Tom Mandera
    Oct 19, 2001
    4,207
    Helena, MT
    I have seen 33x9.50-15 tires on an unmodified 800 body and they fit OK. Actually, I think they had to do something with the quarter panel strut brace behind the rear axle.
    If you stick with narrow axles, and skinny (but tall) tires, they'll fit better on your 80/800 chassis.
    You may still have problems with turning, with the bigger tires hitting the sheetmetal.
    You can work this out by using a tape measure.
    A GOOD suspension lift doesn't allow you to run any taller/bigger tires than you could stock, unless you lower the bump stops a lot.
    In the case of an SOA, the bump stops usually get lowered a few inches, primarily because the bump stops used to hit the axle tube, and now they hit the U-bolt plate on top of the spring pack on top of the axle tube, so that effectively lowers your bump stops.
    But like others.. 33s.. and skinny 33s.
    I have an SOA Scout II and my 31" tires rub - and that's with the bump stops lowered (now sporting air-bumps)
  9. R290
    R290 High Wheeler
    Apr 25, 2005
    1,313
    Sacramento, CA
    You could put 38" on there if you wanted, but remember your turning radius is limited by your tires hitting the leaf springs too.
    I'm thinking 33 would be the largest if you still wanted full turning. That's why Tom said narrow tires.
  10. Hoss Scout
    Jul 27, 2011
    58
    Boyne City
    So some 33-10.5R15 would most likley work....:beer:
