Show me painted SD33T Engines
Discussion in 'Diesel Tech' started by Jim, Jul 11, 2017.
  1. Jim
    Jim High Wheeler
    Oct 17, 2001
    1,171
    29
    Oregon
    Looking for ideas on engine color. Im fine with painting new color other than original aqua green/blue. Ive seen the Lego engine, but want more ideas. Im hoping to find what I need at local parts stores in rattle can. Thinking of some parts in black or other contrast color such as the injector lines and pulley wheel. I recall liking CoopVa's color choice but cant seem to find his engine build thread.
    CoopVA likes this.
  2. CoopVA
    CoopVA Binder Driver
    Nov 29, 2013
    772
    Linden, VA
    It's in my build thread...
    I used VHT SP122 Engine Enamel Pontiac Blue...
  3. Jim
    Jim High Wheeler
    Oct 17, 2001
    1,171
    29
    Oregon
    Yes! That looks so amazing. Im really sold on that color scheme. My coolant plug is just a plug. Do you know where would I find a drain valve plug with hose fitting? It looks like yours is new.
  4. CoopVA
    Nov 29, 2013
    772
    Linden, VA
    Thanks! I'm pretty sure the drain plug is the one that was on there originally. I just cleaned it up and put a new hose on it.
    I will check my factory parts list and see if it's listed. Give me a day or so...
  5. Joe S
    Joe S Farmall Cub
    Oct 27, 2011
    154
    Sunland, Lompoc, CA
    Izat ceramic on the hot stuff?
  6. CoopVA
    Nov 29, 2013
    772
    Linden, VA
    VHT Flame Proof SP-102 Flat Black
  7. CoopVA
    Nov 29, 2013
    772
    Linden, VA
    The parts list shows the block drain as item #250 - COCK-WATER DRAIN part number 21212-90013...
    Mine looks different though...
  8. Joe S
    Joe S Farmall Cub
    Oct 27, 2011
    154
    Sunland, Lompoc, CA
    That's the valve that came on my crate motor.
  9. Jim
    Jim High Wheeler
    Oct 17, 2001
    1,171
    29
    Oregon
    I ended up finding a 1/4 npt threaded petcock valve. The threads arent exactly the same, but close enough.
    What did you use to make your EGR blocking plate? Wondering how thick the steel needs to be. I think I have to make 3 since Im using the original intake.
    CoopVA likes this.
  10. CoopVA
    Nov 29, 2013
    772
    Linden, VA
    Pretty sure the threads are metric. You are setting your self up for leaks if you use the wrong thread...
    I used 1/8" steel for the blocking plate. Should be good...
  11. Alex
    Alex Farmall Cub
    346
    On The, Edge
