Shop Talks
Discussion in 'The Reading Room' started by Colin Rush, Sep 19, 2010.
  1. Colin Rush
    Oct 15, 2001
    2,963
    Portland, by God-Oregon!
    International Harvester published a set of booklets that they called Shop Talks for International Servicemen. The Shop Talks were service instructions that either discussed service procedures not covered in the standard truck service manuals, or they expanded upon topics covered but in much greater detail. They came with very good photographs to demonstrate procedures, and very explicit instructions. Most people don't know about them, not even the dyed-in-the-wool Binderphiles. I learned about them from two friends that worked at Binder Books, who showed them to me when I was looking for some good information for an M-5H-6 I was working with. If you have a service manual that covers any of the following topics, you should get a copy of the Shop Talks for your library. They really are much better information that that listed in the standard service manuals.
    There are at least 48 different topics covered. Below is a list of all Shop Talks that Binder Books has, listed by Shop Talk Number, Topic, Book Number, Issue Date, and number of pages. If you want to order a copy, visit the links above, and then call or e-mail them for a reprinted copy.
    #1 Revised / "Servicing the Two-Speed Rear Axle" / A-233-HH / 1944 / 8 pages
    #2 Revised / "Reconditioning HD Engine Valves and Valve Mechanism for HD Engines in Model D-2, D-3, D-15, D-30, DS-30, D-300, D-186-T, DS-186-T" / A-224-HH / 1944 / 8 pages
    #3 Revised / "Piston Ring Replacement, Oversize Piston-Pin Installation, Connecting Rod and Water Pump, Overhaul the HD Engine" / A-225-HH / 1944 / 8 pages
    #4 / "Tuning-Up the HD Engine" / A-226-HH / 1944 / 8 pages
    #5 Revised / "Series 28 Zenith Carburetor Service" / A-227-HH / 1944 / 8 pages
    #6 / "Preparation of New Trucks for Delivery" / A-67-HH / 1944 / 8 pages
    #7 Revised / "Brake Adjustment Instructions for K-1, K-2, K-3, K-1M, K-3M" / A-83-FF / 1941 / 14 pages
    #8 / "K-1, K-2, K-3 Transmissions (Models HDS and HDS-A)" / A-249-HH / 1944 / 8 pages
    #9 Revised / "K-4, K-5 Transmissions (Model H-41, H-41B)" / A-230-HH / 1944 / 8 pages
    #10 / "Propeller Shafts and Universal Joints -Type DR" / A-231-HH / 1944 / 8 pages
    #11 Revised / "Clutch Overhaul (Models RK-10, RK-10-A used in K-1, K-1-M, K-2, K-3-M, K-4, KS-4, K-5, KS-5, K-5-COE, and KS-5-COE, Single Dry Plate Type" / CTS-38G / 1947, 8 pages
    #12 / "Carburetor Service - 63 Series" / A-72-FF / 1944 / 8 pages
    #13 / "K-Line Cab Service" / A-234-HH / 1944 / 8 pages
    #14 Revised / "Water Pump Service" / A-290-HH / 1944 / 20 pages
    #15 / "Spark Plug Cleaning & Adjustment" / A-128-FF / 1942 / 4 pages
    #16 / Carburetor Service Zenith Series 30, used in K-6, K-7" / A-235-HH / 1944 / 8 pages
    #17 / "Truck Storage Suggestions" / A-182-FF / 1942 / 4 pages
    #18 / "Vacuum Power Unit (Bendix Hydrovac)" / A-185-HH / 1944 / 16 pages
    #19 / "Zenith 29-Series Carburetor" / A-217-HH / 1944 / 12 pages
    #20 / "Theory & Fundamentals of Air Brakes" / A-8-II / 1944 / 16 pages
    #21 / Governor Service for the Zenith Gov-U-Retor" / A-35-II / 1945 / 28 pages
    #22 / Holley Carburetor & Governor Model AA-1G Carburetor and Model 1174 Governor / A-175-II / 1945 / 28 pages
    #23 / "Vacuum Shift Control for Two-Speed Axles" / A-176-II / 1945 / 12 pages
    #24 / "Air Brake Unit Maintenance, Bendix Westinghouse" / A-201-II / 1945 / 22 pages
    #25 / "Timken Double-Reduction Axles S-200-P and U-200-P" / CTS-49 / 1946 / 20 pages
    #26 Revised / "Vacuum Power Unit (Bendix Hydrovac) Third Series-Models 373853, 374750, 374980" / CTS-71 / 1948 / 24 pages
    #27 Revised / "Holley Carburetor Models 847-F and 847-FS / CTS-66G / 1947 / 16 pages
    #28 / "Oil Pump Overhaul, GRD, BLD, and RED Engines" / A-278-JJ / 1946 / 12 pages
    #29 / "Metro Body" / A-305-JJ / 1945 / 14 pages
    #30 / "Vacuum Power Unit (Bendix Hydrovac) Third Series-Tandem Cylinder, 'C' Series" / CTS-74 / 1947 / 20 pages
    #31 / "Holley Carburetor and Governor Model 885-JJSG Carburetor-Model 1174 Governor" / CTS-76 / 1947 / 24 pages
    #32 / "T-97 Transmission" / CTS-77 / 1947 / 8 pages
    #33 / "Clutch Overhaul (Model R-15-8)" / CTS-78 / 1947 / 8 pages
    #34 / "Two Speed Double Reduction Differential & Carrier Assembly; (Timken S-300-P and U-300-P Axles)" / CTS-79 / 1947 / 16 pages
    #35 / "Carter Carburetor-Series BBR-1 Models 615-S, SS, SA, SC, and 656 S)" / CTS-80 / 1947 / 16 pages
    #36 / "International Continental Engine R-6586" / CTS-81 / 1948 / 28 pages
    #37 / "F-55 Series Transmissions - Models 55 (Fuller 5C-650) and F-55-C (Fuller 5C-65)" / CTS-82 / 1948 / 12 pages
    #38 / "Auxiliary Transmission (Brown-Lipe 6231 and 6231-A)" / CTS-83 / 1948 / 12 pages
    #39 / "Brown-lipe Five-Speed Transmission (Models BK 6252 and BL 6253)" / CTS-84 / 1948 / 16 pages
    #40 / "Power Dividers Hendrickson-Models HPDA and HPD" / CTS-85 / 1948 / 20 pages
    #41 / "Auxiliary Transmission (Brown-Lipe 5531)" / CTS-86 / 1948 / 12 pages
    #42 / "Carter Fuel Pump (Model M593S)" / CTS-87 / 1948 / 8 pages
    #43 / "Timken Single Reduction Axles L-100 and R-100" / CTS-88 / 1948 / 24 pages
    #44 / "Silver Diamond Engine, SD-220 and SD-240" / CTS-89 / 1950 / 20 pages
    #45 / Missing, Not Currently Available
    #46 / "Carter Carburetor, Series YF (Models 735S, 736S, 736SA, 740S, 741S, and 741SA)" / CTS-107 / 1950 / 20 pages
    #47 / "12 CX Hydraulic Torque Converter and 2-A-301 Transmission" / CTS-108 / 1950 / 16 pages
    #48 / "Electrical System Diagnosis-Regular Maintenance" / CTS-169 / 1951 / 32 pages
    If anybody has a copy of #45, or anything #49 or up, let me know.
  2. Tad Abley
    Tad Abley Farmall Cub
    Dec 18, 2006
    Athens, GA
    I know this is an old thread.....but I have a copy of #45. I have all originals and am only missing 23,24,29,35,36, and 46. There are also some that were revised and have a "r" after the number i.e. I have 28 and 28r. I have multiples of a few of them, but I do not know off had which ones.
    The list below is taken from the list of Shop talks that I have. It seems to me that after number 48 they quit numbering them. The dates of each manual are in parenthesis at the end.
    CTS-169 48 -Electrical System Diagnosis Regulator Maintenance (4-5-51)
    CTS-170 -Rear Axle (Model R-100 Truck) (2-22-54)
    CTS-171 -HNS Transmission (2-22-54)
    CTS-172 -Transfer Case (Timken T-32) (5-15-54)
    CTS-1173 -Automatic Transmission (8-9-54)
    CTS-1174 -HNS Overdrive Transmission (8-9-54)
    CTs-1175 -CAB (Model CO Trucks) (11-17-54)
    CTS-1176 -Clutch Overhaul (Model Rockford RT-11 Clutch) (1-14-55)
    Tad
  3. michael sharp
    michael sharp Farmall Cub
    Feb 12, 2017
    167
    35
    Park Rapids, MN
    I don't have those but I do have all the "Sales Engineering News Letter"s, "Motor Truck Service Letter"s, " "B" GENERAL LETTER M.T. No. __"s and "Fleet Service News Letter"s from 6/10/63-8/13/54. Some of these mention your CTS-#s and what line , word or paragraph needs to be changed and why. Michael
