SD33 Alternator connector
Discussion in 'Diesel Tech' started by cphmr8604, Mar 12, 2020.
  1. cphmr8604
    cphmr8604 Farmall Cub
    Sep 15, 2012
    26
    Decker, IN
    Hopefully you can see the image. This is the kind of alternator I got from Super Scout Specialists. The upper right corner shows the kind of connection the alternator has. I can't hook this up to anything in my Scout. Are there any adapters available so it will fit the 6 pin harness or is it possible that they grabbed this off an engine that wasn't in a Scout? Any help is appreciated!
  2. blue smoke
    blue smoke High Wheeler
    Sep 28, 2008
    1,282
    64
    Melissa Texas
    There is no adaptors (that I have seen). Did you already send them your alternator as the core?
    But call the they stand up guys who will help you out.
  3. cphmr8604
    Sep 15, 2012
    26
    Decker, IN
    When I bought my SD33 Scout there was a Delco alternator and a separate belt driven vacuum pump. I'm trying to get everything back to factory spec or close to it anyway. So this has been a challenge for me since finding parts for these are not easy. To answer your question, I bought the alternator used sight unseen over the phone. Super Scout Specialists recently bought a big inventory of SD33'S (contradicts my previous statement) and it's hard telling what the engine came out of that they pulled the alternator from. I'm hoping I can return the alternator and get one with the correct connector.
  4. shades
    shades Farmall Cub
    Oct 15, 2003
    69
    Brighton, Co
    I think I used 2 of the 6 wires and ignored the other 4. I have been running this setup forever. I may be able to check and see what pins I am attaching to. I will try to get out there and check it out. I am sure you can find the connector and then just use the two pins. Maybe I could get wire codes or colors and let you know what I did. I think you now have the higher output newer alternator than came with the Scout originally.
  5. cphmr8604
    Sep 15, 2012
    26
    Decker, IN
    I appreciate it!
