SD-33 Oil Filter Seal
Discussion in 'Diesel Tech' started by Joe S, Dec 5, 2018.
  1. Joe S
    Joe S Farmall Cub
    Oct 27, 2011
    181
    Sunland, Lompoc, CA
    Anyone have a P/N and/or source for the beeg square-ring on the SD33 oil filter canister.
    Making an adapter and don't want to buy a filter just to get the seal. The one I have is at least 20 years old and a little stiff.
  2. Dana Strong
    Dana Strong Y-Block King
    3,992
    628
    By "beeg", you mean big?​
    If you can accurately measure the ID, OD and thickness, you could probably find a "Quad Ring" (X-ring) which is a squarish version of an "O" ring that seals more easily to replace it with. Marco Rubber has size charts for all three types (O-, X-, and Square) here:
    Once you know the size, there should be some local distributor where you can get just one or two without the hassle of ordering and paying shipping too.
  3. Joe S
    Joe S Farmall Cub
    Oct 27, 2011
    181
    Sunland, Lompoc, CA
    You've made me think about this and it didn't even hurt.
    I'm not using a seal where the filter has the wide gasket on its base. Going metal to metal there. That was making using the original square ring on the outside a problem in trying to get enough squeeze on it to seal but not so much that the adapter didn't make contact where it needed to. The stock filter has a specified torque on the housing bolt with the internal spring that makes how much the square ring compresses a non-issue.
    Using an o-ring solves that. There are standards for how much you want to squeeze an o-ring in a static sealing application.
    Thanks!
