Scout II wiper motor removal?
Discussion in 'General IH Tech' started by Patrick Morris, Nov 7, 2004.
  1. Patrick Morris
    Patrick Morris Y-Block King
    3,872
    165
    Hi folks... I'm trying to trouble-shoot a wiper problem. The wipers have been working more slowly than normal recently, and now they barely work at all--in fact I'd say they don't at this point. I determined the motor is getting 12v when the switch is ON and it is grounded. So I am now trying to get the wiper motor out to see if it's corroded or by some other problem in need of fixing.
    I have the cowl piece off and have removed the three bolts that hold the motor in place. It's loose but I cannot figure out the right way to disconnect it from the wiper arm and pull it out. What's the trick?
  2. Patrick Morris
    3,872
    165
    BTW, don't know if it matters, but in case it does: It's a '78 w/ 345 engine, 4-speed, no A/C.
  3. BigEddie
    BigEddie Binder Driver
    Aug 1, 2003
    606
    Raleigh. NC
    I just pulled the whole assembly. You can remove the wiper arms and then loosen the rings that hold the splined stubs to the windshield frame. There should be enough room to remove the motor and connecting arms together.
    Of course, removing the whole windshield frame makes it really easy, too!
  4. GregF
    GregF moderator Staff Member Moderator
    1,006
    Milwaukie, Or.
    The long arm that connects to the passenger side wiper shaft has a sliding clip on the end of it. Feel for the clip(it will be on the back side if I recall) and slide it towards the passenger side and that will allow the arm to come loose. Then remove the motor assembly with the long metal bar still attached.
    Your motor problems are most likely related to worn brushes in the motor and or contacts inside the gearbox assembly. I'm not sure if worn brushes can be replaced. Others who have had brush problems should chime in now.
    Greg
  5. Patrick Morris
    3,872
    165
    Thanks guys. I've run into the typical problems with jobs like this. I cannot remove the whole assembly (as BigEddie suggested) because I cannot get the pass. side wiper 'axle' out of the windshield frame---the round nut-like thing holding it in just spins with the piece it's supposed to unscrew from. And though I have slid off the clip (that Greg mentioned) it didn't exactly pop apart at that point, and I am unsure of exactly which pieces to pry on, so I've been conservative with the force I'm applying. I'd hate to break something. I tried spraying everything with that PB stuff everyone raves about and letting it sit overnight, but it did not do any good.
    But it's all good advice and I thank you. I guess I'll get it apart somehow.
  6. jrmtx
    jrmtx Farmall Cub
    Apr 4, 2012
    71
    Brackettville, Texas
    I hope someone is still following this thread since it is quite old.
    I am also trying to remove the wiper motor from my 77 Terra in an effort to get the wipers to work. I have located the clip by the pass side arm but the SHORT lip on the clip is as sharp as a razor and does not want to slide in any direction except for a fraction of a mm. Any suggestions on how to get the thing to slide?
    By the by, I have completed the install of my Holley 2300 carb and now the truck runs beautifully!!! Thanks to all who pointed the way to this conversion.
    Jim
  7. fredsterra
    fredsterra Y-Block King
    Oct 7, 2005
    3,607
    49
    Hanson KY
    I was having issues a couple of years ago. I removed the motor and one cover plate. Then cleaned with 2 cans of electric parts cleaner and works 100% better.
  8. Patrick Morris
    3,872
    165
    Wow. Yep this is old. I guess I must have gotten the wiper motor out somehow by now. :)
  9. jrmtx
    jrmtx Farmall Cub
    Apr 4, 2012
    71
    fredsterra, when you removed the motor was the short control arm moving freely? Mine does not move at all. I removed the cover but the only inside was the electric contacts, a nut and washers in the center which I thought would let the short control arm to be removed. I had read that there was some sort of gear assembly but nothing like that was visible.
  10. Hogie6
    Hogie6 Farmall Cub
    Nov 28, 2014
    17
    Alpharetta
    Can somwonw give me some help on how to remove the wiper arm?
  11. jeff campbell
    12,037
    301
    get a decent flat bar or screwdriver, and just kinda pry up on it REAL easy a lil on this side and a lil on that side. it'll work right up. don't get in a hurry, slow an easy just like OLD people F&%# ! put something under the end of your pry,so you don't scratch it.
  12. jtorre4272
    jtorre4272 Binder Driver
    Nov 19, 2014
    933
    159
    Dearborn, MI
  13. jeff campbell
    12,037
    301
    i was alway's told " there's a tool for every job ! "
  14. Patrick Morris
    3,872
    165
    Well don't ask me. It's been 13 years since I did this. LOL
  15. scoutboy74
    4,923
    219
    To my recollection, there is a very thin gauge tab/clip that helps to lock the wiper arm onto the knurled part of the shaft. The tension on that clip should be released in conjunction with a careful upward prying motion applied to the arm where it rides on the knurled knob. It helps to be abnormally tall or to stand on a sturdy step stool so that you can be up high enough to actually tower over the wiper for a good view of the nether region that is revealed when you bend the hinged part of the arm up as if you were getting it out of the way to wash the glass.
