Scout II Rallye wheels?
Discussion in 'General IH Tech' started by S.H.A.F.T., Sep 6, 2013.
  1. S.H.A.F.T.
    S.H.A.F.T. Farmall Cub
    Aug 19, 2002
    359
    Millersville, PA
    I have a set of four really nice chrome Rallye wheels. I have had them for a while and plan to put them on my Scout II when I restore it. The guy I bought them from said they are Scout II wheels. I was cleaning them up today and noticed a stamp on one of the wheels that says 2-27-70. If that is the date of manufacture, how can they be for a Scout II? The photos of Scout II wheels I have seen are identical to mine. I guess I want to know if mine are for a Scout II or an 800. I have nice centers for them too.
    S.H.A.F.T.
  2. Myron B
    Myron B Farmall Cub
    Mar 19, 2011
    198
    Joaquin, Texas
    Hi..
    IH did not manufacture wheels. They just bought wheels from the wheel manufacturers. Likely your wheels were also used perhaps on other IH models or by some other auto manufacturer or even as after market wheels before IH opted to use them on the Scout II.
    Myron B
  3. Dennis Bernth
    5,967
    35
    Mill Creek, IN.
    Best case scenario is that they are Scout 800 rally wheels, they're worth a lot more money than Scout II wheels. What I would do first is mount one the front of the Scout II and make sure it will clear the disc brake assembly. If they are in fact Scout 800 wheels, they're made to fit with drum brakes and may not clear the calipers on Scout II discs. If that's the case, then you can't use them anyway, sell them to an 800 restorer that needs a set of original wheels. It's hard to tell them apart, the wheels do look pretty much identical.
  4. Nick Rayer
    Nick Rayer Binder Driver
    Oct 17, 2001
    547
    Dexter, Michigan
    Do a search on here. This has been covered in the past with good photos to compare to. There is a slight difference between the two. The date stamp is correct for an 800 wheel. Motor wheel was the manufacturer of the wheels, in fact i have an old off road magazine from the early 70's that has an add from motor wheel for those exact chrome wheels in it. Looks like you could purchase the same wheel aftermarket in a variety of bolt pattern even.
    Nick
  5. S.H.A.F.T.
    Aug 19, 2002
    359
    Millersville, PA
    I rememberr reading an old post and someone described exactly how to tell the difference between the 800 and the Scout II wheels. Darn if I can find it though. Anybody remember the post I'm talking about? Your right, trying to mount one up on the front would tell me for sure. My situation does not make that easy however.
    Back to the search button......
    S.H.A.F.T.
  6. Comanche Scott
    Comanche Scott High Wheeler
    Aug 28, 2010
    2,371
    183
    Tracy, CA
    Actually both the Scout 800 Rallye wheel, and the Scout-II Rallye wheel will bolt up to Scout-II disc brakes.
    Here is a picture of the Scout 800 Rallye Wheel which has a smooth curve. The Scout-II wheel has a more pronounced brow, like a GM Rallye wheel.
    Hth,
  7. Comanche Scott
    Aug 28, 2010
    2,371
    183
    Tracy, CA
    Here is a picture of the "brow" on a Scout-II Rallye wheel. Both wheels are mounted on the same 1976 Scout-II axle with disc brakes.
    Scott
  8. S.H.A.F.T.
    Aug 19, 2002
    359
    Millersville, PA
    Commanche Scott, your the man. Based on your pictures I am pretty darn sure I DO have Scout II Rallye wheels. The differences are subtle going by pictures only. BUT, if they are 800 wheels and will still bolt up, I'm fine with that. These wheels are in super nice condition and if they fit then they are going on. I think the Rallye wheels look sweet. I just finished more searching and I still can't find the post with pictures the other poster mentioned. I know the post he is referring to, just can't find it. Thanks again all.
    S.H.A.F.T.
  9. Eric VanBuren
    May 7, 2004
    6,011
    Maple Valley , Wa
    That is the first I've heard of Motor Wheel as the ones I have are stamped with KH representing Kelsey-Hayes, though they did also sell wheels under the Western Wheels brand in the 70's so maybe Motor Wheel was one of their other aftermarket brand names.
  10. S.H.A.F.T.
    Aug 19, 2002
    359
    Millersville, PA
    I googled both companies and got quite the history lesson. Pretty cool. Had no idea my question would teach me so much. Thanks again fellas.
    S.H.A.F.T.
