Scout 800 Window Tilt Adjust
Discussion in 'General IH Tech' started by 76rallye, Jun 11, 2020.
  1. 76rallye
    76rallye Farmall Cub
    Sep 20, 2010
    207
    27
    Marblehead,MA
    I need to adjust the height of my 70 Scout 800 Door Glass.
    Back of the glass sits higher when rolled all the way up.
    I'm aware of the adjustment located on the hinge side of the door.
    Reading thru some threads, I saw a mention of an adjustment for the tilt of the glass somewhere on the regulator.
    Does anyone have a pic as I can not locate it; I'm assuming the regulator does not need to be removed.
    Thank You
  2. Don B
    Don B Binder Driver
    Dec 23, 2018
    705
    246
  3. 76rallye
    Sep 20, 2010
    207
    27
    Marblehead,MA
    Thank you, but I do have that pic but just don't see it anywhere.
  4. Don B
    Don B Binder Driver
    Dec 23, 2018
    705
    246
    Maybe it’s missing. Take a look at the bottom inside of the door in case it fell off. Get the machine screw too. If you are missing it you’ll have to get one. BTW, it’s on the flat white plate which the regulator arms go into not the regulator as the instructions state...the picture is correct though.
    Don B
  5. 76rallye
    Sep 20, 2010
    207
    27
    Marblehead,MA
    Yup it’s missing on both doors.
    Any real pics as I can’t see what a screw is going to do to set the tilt unless there is some sort of bracket that puts pressure on the reg arm.
  6. jeff campbell
    15,379
    1,513
    It holds the eccentric tight to the position you set it at
  7. jeff campbell
    15,379
    1,513
    Will look in the AM. Get pics
    stroker3 likes this.
  8. 76rallye
    Sep 20, 2010
    207
    27
    Marblehead,MA
    If possible, that would be appreciated. Thank you.
  9. jeff campbell
    15,379
    1,513
    I looked an not see it.still all together.
  10. 76rallye
    Sep 20, 2010
    207
    27
    Marblehead,MA
    I need two of them.
    Anyone know of a substitute part or have two they are willing to sell?
  11. RinTX
    2,231
    738
    Looks like something that could be easily made - if you had one to copy.
  12. jeff campbell
    15,379
    1,513
    I found 1.will look tonite again for another.now i know where its located at. 20200615_082952.jpg 20200615_082958.jpg
  13. Don B
    Don B Binder Driver
    Dec 23, 2018
    705
    246
    Should be fairly easy to fab up. Mine are out sitting in the basement so I can measure them up if you need the specs.
    Don B
  14. JeffsScout
    JeffsScout Farmall Cub
    Apr 7, 2020
    I seem to be missing these as well. Would you be able to send some sort of a sizing diagram so that I can reproduce them? Any help you can lend would be greatly appreciated.
  15. Don B
    Don B Binder Driver
    Dec 23, 2018
    705
    246
    I am at our cottage right now but will do so when I return on Sunday.
    Don B
  16. Dana Strong
    5,633
    1,404
    If you get some measurements and post them here (including diameter, thickness, bolt/hole size), I could easily make a few if needed by anyone.
  17. Don B
    Don B Binder Driver
    Dec 23, 2018
    705
    246
    Will do, maybe even a swanky diagram! Fishing right now.
    Cheers
    Don B
  18. Don B
    Don B Binder Driver
    Dec 23, 2018
    705
    246
    Photo with diagram attached. I didn't measure the screw bevel but you get the idea. It looks like the adjuster was zinc plated so you might want to do the same.
    Don B
