Scout 800 SOA R.S on SII axles
Discussion in 'Canyon Offroad' started by az scout guy, Jul 26, 2013.
  1. az scout guy
    az scout guy Binder Driver
    May 31, 2009
    656
    Apache Junction,AZ
    Since we haven't done a write up on our SOA with Scout II axles on an 800 I figured I would put this one up. Also our rear disc conversion and P.S conversion
    [​IMG][​IMG]
    We started with a stock 71 800B, Dana 30 front and dana 44 rear
    Start with the cut and turn and chevy flat top knuckles[​IMG]
    Re drilled chevy flat tops to use scout outers[​IMG]
    Here is our disc brake kit for Scout II dana 44 or 69-71 800's[​IMG]
    Axles ready to be cleaned and perches welded on[​IMG]
    Front ready for paint[​IMG]
    One side of the rear disc conversion installed[​IMG]
    Painted with 4.30 gears installed ready for install [​IMG]
    The new Sky manufacturing super tall arms[​IMG][​IMG] tearing the old stuff out[​IMG][​IMG]
    Out with the old in with the new[​IMG]
    We chose to use the IH Parts America R.S fangs ( these guys are awesome):punk:[​IMG]
    [​IMG][​IMG]
    Going in[​IMG]
    [​IMG][​IMG][​IMG]
  2. az scout guy
    May 31, 2009
    656
    Apache Junction,AZ
    Sitting on the ground for rear pinion angle and shock setup[​IMG]
    Mocking in the p.s box, we plate the frame and sleeve it[​IMG]
    The pump bracket all mounted up[​IMG]
    Then the Scout gets a custom cage[​IMG][​IMG]
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    [​IMG][​IMG]
    A set of Canyon Offroad hinges[​IMG][​IMG]
    :punk:
  3. David Hinkle
    David Hinkle Farmall Cub
    Aug 1, 2010
    austin,tx
    let's see those pictures
  4. az scout guy
    May 31, 2009
    656
    Apache Junction,AZ
    Not sure where the pics went but ill get them up
  5. az scout guy
    May 31, 2009
    656
    Apache Junction,AZ
    are the pics working now
  6. Bill USN-1
    17,120
    289
    Your links start with https which means they are on a secured site that requires a password.
    https://photos-4.dropbox.com/t/0/AABFhXilGKzE9jEg2E8dcATZiUg
    No one else can see them unless they have a login to that site.
    You need to host them on a regular server or just upload them to your own folders right here on the BP like I do. Then you can just hit the "insert photo from albums or photopost" link right above the text window.
  7. az scout guy
    May 31, 2009
    656
    Apache Junction,AZ
    [​IMG][/IMG][​IMG]Ok until I have more time heres some teaser pics[​IMG]
