Scout 800 rear end noise
Discussion in 'General IH Tech' started by Greg704, Jul 27, 2014.
  1. Greg704
    Greg704 Farmall Cub
    Dec 22, 2013
    109
    MARSHVILLE
    My
    1967 Scout 800 has a lound hum when you get around 50 miles an hour. is is only when im on the gas. Any ideas of what it could be. comes from the Rear end middle. it is a dana 27.
    below is a link to a video of the issue. hard to hear it but its there.
    https://www.youtube.com/watch?v=7ZsR5qepVsA
    thanks
  2. Greg704
    Greg704 Farmall Cub
    Dec 22, 2013
    109
    MARSHVILLE
  3. Alex
    Alex Farmall Cub
    418
    40
    On The, Edge
    U joint?
  4. Greg704
    Greg704 Farmall Cub
    Dec 22, 2013
    109
    MARSHVILLE
    I replaced the u joint whin I changed a gasket.
  5. TheScoutMaster
    TheScoutMaster High Wheeler
    Aug 1, 2002
    2,127
    35
    70 Miles North of Hell
    Did it start making noise after you changed the U-joint, or was it present prior?
  6. Greg704
    Greg704 Farmall Cub
    Dec 22, 2013
    109
    MARSHVILLE
    It was there be fore. It only dose it when it is under load. Whole I'm on the gas. Not coasting.
  7. john breeze
    john breeze Farmall Cub
    Jul 30, 2005
    465
    prosser, wa
    pop the differential cover off and check to see what the gears look like.
  8. TheScoutMaster
    Aug 1, 2002
    2,127
    35
    I would also look at your bearings, carrier and pinion...
  9. Greg704
    Greg704 Farmall Cub
    Dec 22, 2013
    109
    MARSHVILLE
    The plan. i'm going to change the Pinion Bearing, cup and seal. Hopfuly that will fix it
  10. Doc Stewart
    49
    Better to diagnose the problem before you throw parts at it especially in a differentiaL
    Try taking it to a diff shop for their estimate... Usually no charge but check first.
  11. Greg704
    Greg704 Farmall Cub
    Dec 22, 2013
    109
    MARSHVILLE
    I have found the problem. i believe, or at least a problem. The pinion shaft lock pin has
    dropped out. The "pin" is a screw. (see pic) with out the pin shaft would flod abound. there are a few dinged gears but nothing major. Should this be a roll pic? this dose not seem like this is the right park. thoughts ?
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
