Scout 800 power steering
Discussion in 'General IH Tech' started by Blackdog, Sep 18, 2003.
  1. Blackdog
    Blackdog Binder Driver
    Oct 17, 2001
    849
    Zillah Wa
    Will the power steering from a 800a V-8 Scout fit on my 800 4 cyl Scout?
  2. grannygear
    grannygear High Wheeler
    Jan 8, 2002
    1,127
    Castaic, CA
    AAhhh...
    ...I don't think any 800 came with power steering. My V8 800 did not. I swapped on SII stuff.
    There are other options for the 4cyl ones. The box is on the inside of the frame...yes? The V8s manual box mounts to the outside of the frame.
  3. Justin Graham
    Justin Graham Farmall Cub
    Mar 13, 2003
    179
    Quitman, GA
    4 cyl. Power Steering
    There's a write in the FAQ about converting a 4 cyl. Scout 80/800 to power steering. Little different the V-8 conversion because the box in mounted on the inside of the framerail. Need to use the box from a 78-79 F250, probably could use the pump from a Scout II with a custom made bracket. I've been comtemplating doing the conversion on my '63 Scout 80, so I've done a little bit of research. Members REF and Trad Bowhunter Dan have done the conversions, they may be able to provide you with a little insight. Good luck.
    Justin
  4. Damian Grihalva
    Damian Grihalva High Wheeler
    2,154
    Colorado Springs
    I've heard of the ford box, and I've seen it work ~ I used a Scout II box. Put the whole write up on my website. Click on: http://www.dandcextreme.com/extremebuildups.asp - then Click "Beater Buildup" and the write up is on "Day 33" through "Day 35" ~ but the box mount is on "Day 34" ~ I've even got pictures of both the ford box AND Scout II box going in.
    Check it out.
    Travis W likes this.
