Scout 800 5spd question
Discussion in 'Southeast Binders Association' started by Quilmes, Feb 16, 2015.
  1. Quilmes
    Quilmes Farmall Cub
    Dec 23, 2005
    197
    Orlando, Fl
    Ok guys need some help, hopefully it is not a dumb question.
    I have a 69 800 with a 392 4spd.
    Here is the question, does the Travellet/Travelall 5spd 4x4 fit on my Scout. If not please explain why?
    Thanks in advance
    Martin
  2. timscout1
    timscout1 High Wheeler
    Mar 23, 2004
    1,214
    Page,AZ
    The easy answer is no, the 5 speeds use a different bellhousing and worse than that a separate 205 transfercase. The tranny and xfercase is lots longer plus used a intermediate drive shaft.
    Almost anything can be fitted if you have BIG$$$ to spend, but even then the short wheelbase limits options. Good Luck
  3. jeff campbell
    14,984
    1,338
    a 5-spd., would be WAY overkill for a scout ! ? why ? jeff
  4. BO185
    BO185 Y-Block King
    Jun 8, 2004
    3,449
    189
    Jacksonville, Arkansas
    Be easier to do a NV4500 and married case. All the a IH 5 speeds were 2wd only. IHPA sells adapters for the NV4500 and will give you an OD.
  5. Quilmes
    Quilmes Farmall Cub
    Dec 23, 2005
    197
    Orlando, Fl
    Thanks all for the quick response, I was just wondering, as the NV4500 seems to be the choice many prefer. I was not sure why nobody was keeping it all IH, but I was not aware of the divorce transfer case. So yes that makes it extremley difficult.
    Again thanks
    Martin
  6. 72soa
    72soa Binder Driver
    Oct 23, 2003
    963
    152
    Oak Hill, FL
    Part of that difficulty involves cutting up and rebuilding the floor of the scout to accommodate all of the related infrastructure needed for such a swap.
