Running a Stock SD33T with biodiesel
Discussion in 'The BioDiesel Plant' started by Landry, Mar 23, 2012.
  1. Landry
    Landry Farmall Cub
    Feb 23, 2012
    17
    Waco, TX
    Running a Stock SD33T with biodiesel---is it just a matter of changing a couple of rubber hoses, or is there some required "conversion kit" or something?
    What mpg can I expect?
    How is the engine performance?
  2. Landry
    Landry Farmall Cub
    Feb 23, 2012
    17
    Waco, TX
    Hmmm...No replies all day. Maybe I should have posted this question on another forum?
  3. Brian
    Brian Farmall Cub
    Nov 15, 2001
    246
    Cheyenne Wells, Colorado
    No bio diesel within 60 miles so I dontmhave any experience with it. . .
    Anyone else?
    Brian
  4. tinker
    tinker Farmall Cub
    Aug 16, 2003
    338
    Berkeley CA
    The SD33T or NA run fine on 100 percent biodiesel. When you first switch over, the biodiesel will dissolve years of crud in the tank so be prepared to change fuel filter a few times.
    After some months the biosiesel will soften the rubber fuel hose and it will need to be replaced with the 30R9 hose. The nylon fuel line should be fine.
    After that you should be good for years of running BD or petrolium.
    The new ultra low sulfer fuel is also hard on hose so everyone may have to do the hose upgrade even without switching to BD.
    Next when you are ready to run used vegetable oil post again!
    Danny
  5. Sammy
    Sammy Y-Block King
    Oct 22, 2001
    3,020
    385
    Grigsby's Bluff, TX
    I have no idea what 30R9 hose is but I would use viton. That may be what 30R9 is, but it isn't cheap. I just changed the filter on a powerstroke for the first time running bd for 10K miles. This truck had 166K when I started using it. But you should be changing the filter every 20K at the least. I would also suggest adding a water separator to your stock fuel filter. Yes, you can still use the stock nylon line. Your mpg should be really close to what you're getting now, shouldn't have any noticeable drop. Change the hoses as soon as possible the bd will eat the natural rubber lines alive.
