Removing 1971 travelall 4x4 front drum
Discussion in 'General IH Tech' started by DoublecabTravelall, May 23, 2020 at 10:09 AM.
  1. DoublecabTravelall
    DoublecabTravelall Farmall Cub
    Jan 20, 2020
    30
    Abilene, TX
    I finally got the star loosened and the drum is turning freely by hand. Finding the star was difficult as it does not line up with the access hole. I have soaked the studs and around the hub with penetrating oil and tapped all around with a hammer to try to loosen the drum. It appears the drum slips over the hub but nothing is budging. Not even a wiggle. Am I missing a step? Any advice?
  2. jeff campbell
    15,221
    1,446
    Take it off all in 1 piece. Tear apart locking hub to get to the nut.
    stroker3 likes this.
  3. Jeff Jamison
    7,461
    982
    Those drums are swedged to the studs.You need to remove the drum/hub in one piece ,remove the locking hub,then the big nuts and pull it all off
    Big Ed likes this.
  4. Big Ed
    Big Ed High Wheeler
    Sep 29, 2010
    2,523
    432
    Fresno,Ca
    ^This, my 71 Travelall was the same stock.
  5. jeff campbell
    15,221
    1,446
    Once off then never seize them .
  6. Jeff Jamison
    7,461
    982
    I wouldn't do that Jeff,they are pressed in,not suppose to come apart unless you use a swedge cutter .You need to drive the studs out to separate.Only time you need to is for new drums,that I don't know if you can get or not.
  7. DoublecabTravelall
    Jan 20, 2020
    30
    Abilene, TX
    Thanks everyone. I had never heard of swedged studs.
