Readers Rides
Discussion in 'Injection Tech' started by Bill USN-1, May 11, 2006.
  1. Bill USN-1
    17,068
    257
    OK, you guys have seen how I did it...
    Now it's your turn to post up a couple pics of your conversion for us to see!!
    Don't be shy!
    Here's a couple after initial assy!
    76 Scout
    75 Scout
  2. Dave Clifton
    Dave Clifton Farmall Cub
    Jun 21, 2005
    178
    Westminster, CO
    OK, I'm game. But I was waiting until I was finished. But I can show a couple of things: Haven't figured out the insert image tool yet. So I'll have to post the photos at the bottom. You'll have to match the photo with the description...
    1. Finished Duraspark Disty
    2. Glove box with ECM. SES light upper left next to radio.
    3. EST/coil mount plate
    4. Firewall power center. Fuse holder, OEM Fuel pump relay/MAP sensor & power relay for Ign, ECM, and O2 sensor heater.
    5. Still Spaghetti.
    Obviously still a quadrajet. Waiting for the Transdapt adapter plate.
    I have new valve covers and intake plenum to photo when everything is finished. So more pics to come.
  3. Home Built
    Home Built Farmall Cub
    Apr 22, 2006
    115
    Redding Calif.
    Well I guess someone has to go first....
    Here is the engine compartment, just a little more cleaning up to do and wrapping of the wires and it will look pretty..
    This was the part that really had me stumped for a while and I thought I'd share what I did with others incase someone else ever had the same problem.
    I have an older chevy engine and it does not have a threaded drain plug into the water jacket for an knock sensor. And the one threaded plug I had was a little bitty thing right behind the collector on my headers.
    So I got creative, I got a steel freeze plug and a threaded adapter that the knock sensor threaded into and then drilled a hole in the center of the freeze plug. Threaded about 2 threads thru the hole and then carefully welded a tight little bead around it and checked it for leaks. Go figure I got it on the first try. Hammer in the new plug and thread in the knock sensor. There is enough room to get a wrench on the adapter so when I put in or take out the knock sensor I don't have to worry about twsiting out the freeze plug.
    I pretty much followed Bill's instructions and it went real smooth.
  4. Binderman
    Binderman Binder Driver
    Jun 21, 2002
    688
    Crowell Texas
    I'll play!! Since there are only a hand full of use FI'ed 80/800 guys I better post up. :D
    I too followed most of Bill's instructions, only I modified then a tad to fit the 800 as I saw fit.
    At first Bill and I were worried the distance from the manifold connection to the MAP sensor was gonna be to far and might cause problems. No ill effects as of yet.
    I will say the fuel system mods are the biggest hurdle to overcome when doing a 800 conversion. Means of fuel return to tank have to be added, the OEM suction line into tank is to small so it has to be replaced, then ya gotta multiply all this by two so you can use the other tank when finished also. I have yet to hook my other tank into the system. :eek:
    [​IMG] [​IMG] [​IMG] [​IMG]
    All though the FI conversion is the only major mod I have made on the truck, I'm gonna be hard pressed to find a better one to do later on!!! It don't get no better than WORKING fuel injection!!!
    Thanks Bill!!!
  5. ldo_marlin
    ldo_marlin Farmall Cub
    Aug 12, 2004
    58
    westminster,ca
    This conversion may not be on a IH motor. It's a SBC BUT nevertheless I'd like to share some initial observations going from a Quadrajet to TBI. May be this will help some of you that are contemplating a conversion. Bill-USN1 helped me out on a couple of bin files from the ALDL data. I studied the changes he made with the corresponding ALDL data and got the hang of it. Thanks for the help Bill! I still have a lot more tuning cycles ahead.
    Pros:
    -Cold start is great. No more waiting for warm up. Start it and go
    -Idle is solid
    -No hesitation throttle response
    -I can run 87 octane now. I had to run 91 before
    -No more foul plugs every 5K miles
    -You can tweak (tune) forever (if you like to tinker)
    - Tune and not get greasy.
    Cons:
    -Initial mpg is 10.5 vs. 12 for the Qjet (Initial chip was set up too rich and timing was off. I am pretty sure when tuning is done, TBI will beat the Qjet on mpg)
    -If you want to program your own chip, it requires an initial investment in a programmer, UV eraser, laptop and Eproms.
    -Need patience.
    -Cost
    So if you are on the fence, just do it. It’s worth it. These are just my views. Your mileage will vary……
    Pictures here:
    http://pg.photos.yahoo.com/ph/ldo_m...=&.done=http://photos.yahoo.com/ph//my_photos
    And here are some specs of the truck:
    Suburban K20
    355 SBC . Zero deck 9.5:1 compression. Balanced
    Stock iron heads, Pocket ported. 1.94in. 1.6”ex.
    Crane Powermax 266H .440”/.454” . LSA:114
    Edelbrock intake, BBC TBI with 350 injectors. AFI wiring harness. AFPR, All GM sensors except knock and VSS.
    MSD6A, MSD Coil
    Headers, Dual 2.5” exhaust.
    SM465/NP208,
    4:11 R&P Powertrax Noslip locker rear 33”BFG A/T
    Dual batteries, 190A alternator
    McIntosh Headunit and Amp. Eclipse Preamp & Sub. Infinity Perfect separates
  6. Chrispucci
    Chrispucci High Wheeler
    Oct 16, 2001
    1,984
    Newberg, OR
    Here is my Scout on TBI:
    '72 Scout II
    Worn out 304
    T-19
    Dana 300
    SOA
    Full width Chevy D44/4.56/Lockright/Discs
    Full width Corp 14 bolt/4.56/Welded/Discs
    36" Irok
    Aggresive fender trimming ;)
    Bobbed rear
    Cage
    And just about nothing else.
    So far I have been running for about 10 days. I still have some data logging to do and some tuning to do. But it makes great power - starts easy and doesn't stall!! I can lug it around at 400 rpms. BUT - I have a poor idle and I'm still nervous when I drive it around. And the racket the fuel pump makes is pretty bad!
    REAL EFI PICS TO COME!
  7. binderbird
    binderbird Binder Driver
    Oct 11, 2004
    905
    Wichita, Ks.
    Here's a few pics of the MS-II conversion I am doing. It's still running on the Thermoquad. MS-II isn't recognizing the dizzy signal. I stuck the MS box in the glove box with the relays and fuses. Aslo a dew pics of us goofing off.
  8. Tom Mandera
    Oct 19, 2001
    4,297
    45
    Helena, MT
    Where did the braided fuel lines come from?
  9. Bill USN-1
    17,068
    257
    GM used it on certain vehicles.
    Some trucks some cars. Just have to luck into them.
  10. EagleMark
    EagleMark Banned
    Dec 18, 2001
    1,169
    North Idaho
    Old pictures of my first EFI Scout.
  11. Bill USN-1
    17,068
    257
    OK I know there are a lot more conversions out there!!
    Post them up!!
  12. rfleck
    rfleck Farmall Cub
    Nov 30, 2005
    98
    Summit, WA
    Here are some pics of my continuing project. Bill USN-1 and this community deserve most of the credit for this project being as far along as it is... and it is almost dialed in. I would have posted sooner...but I needed to use my wife's camera :eek:
    The guage is from Northern Tool, PN 53653. The fuel pump is from NAPA, PN P5001.
    I need to redo a couple of wires in the harness, which you will see in the pic. They tell me they use a machine now, so this shouldn't happen.
    71 800BFI/345/727/D20/D60/D44
  13. rfleck
    rfleck Farmall Cub
    Nov 30, 2005
    98
    Summit, WA
    Some more pics. I am using the stock air cleaner right now as you can see in the pics. Because of the TPS sensor (mine is taller then some of the pics I've seen) I had to use a 1/2 inch spacer...that I found someplace. I need to find a cold air source to supply the TB. I like the Caprice unit the Airaid-type unit I have seen pictures of in this forum, but I need to find someplace to run a snorkle. Any suggestions?
    You can see one of Bill's chips in the ECU. The ECU looks pretty banged up, but works fine. Interesting to note, I have another ECU I pulled from a local JY that looks brand new. When we finally dial this one in, I am going to try and set it up as a spare.
    One thing I would do differently, or will do differently the next time :) is use a longer harness. Another 1.5 - 2 feet and I would have been able to put in in my Tuffy center console. Something about the computer in the glove box...some kid breaks in and grabs it thinking it is CD changer or something, and I'm stuck.
  14. 84cruiser
    84cruiser Farmall Cub
    Aug 2, 2007
    120
    Castle rock
    Im very proud of my install, if you guys really wanna see a toyota install. I cant post attachments yet, but when I can I have tons of pictures if you wanna see em.
  15. 84cruiser
    Aug 2, 2007
    120
    Castle rock
    That is awesome, I would love to see that in person some day.
  16. 73jeep
    73jeep Farmall Cub
    Jun 18, 2007
    80
    hanover, nh
    Thought you guys would like to see some pics of my new tbi setup, i have a few bugs to fix but i like it so far!
    I dont think i could do it with out this board!
  17. Moq145
    Moq145 Farmall Cub
    Oct 26, 2006
    79
    Summerfield, Fl
    Ok all you guys out there here's some pic of mine!
  18. lhc_cj7
    lhc_cj7 Farmall Cub
    Apr 8, 2007
    56
    Lake Havasu, AZ
    1980 CJ7, I6 258cid, dana 300 and T176 4 speed. Glad this board is around otherwise I doubt this install would have happened. It was fun and learned quit a bit.
  19. littlepiston
    littlepiston Farmall Cub
    Jan 5, 2008
    41
    carlsbad
    i found mine in a chevy truck 1987 3/4ton 4WD 5.7 TBI theres another set if anyone is interested i will remove them and ship for a small handling fee:sailor:
  20. cadpwrdscout
    cadpwrdscout Farmall Cub
    Jul 25, 2006
    31
    Warrior, AL
    Thanks to all the great info on this site...here is my lil heep, 500 cid cadillac engine, th400, dana 60's frt and rr, np205, and etc...again thanks....
