Rag joint question....
Discussion in 'General IH Tech' started by Stevodod, Jul 14, 2015.
  1. Stevodod
    Stevodod Farmall Cub
    Dec 30, 2014
    182
    Jacksonville, FL
    My wife lost her job for 2 months and all money went to food and useless crap like that, so the project was on hold. Now, back in full swing!
    I noticed that the rag joint (not sure what else it is called) has a lot of slop and play....is there a rebuild kit for this and where to get it?
    Thanks all!
    Stevo
  2. binderbound
    binderbound High Wheeler
    May 26, 2002
    2,211
    Redmond, Or
    Borgeson U joint is the best replacement IMO. If that's too rich for your build right now, you can buy the rubber inner for the rag joint off the shelf at NAPA.
  3. scout2000
    4,788
    1,426
    The budget answer is that you should be able to get a new rag joint from most of the Light Line dealers.
    The best answer, assuming you have funds, is to convert to a borgson style joint.
  4. Stevodod
    Dec 30, 2014
    182
    Jacksonville, FL
    Thank you so much! Found the borgeson one! I'll rebuild the stock first, but going that way soon!
  5. David Banner
    David Banner High Wheeler
    Apr 19, 2003
    1,434
    225
    Galloway, OH
    Be sure and buy as decent a ragjoint fix kit as you can find!!! The ones on the "help" shelf are made from an inferior rubber and don't have the metal mesh embedded in the rubber like the oem and will only last a year of DD use.
    Hopefully napa's pos is a better quality...
  6. Stevodod
    Dec 30, 2014
    182
    Jacksonville, FL
    I have O'Reilly's, Auto Zone, Napa, and Advance to choose from....locally anyway....is a rag joint hard to remove?
  7. fredsterra
    fredsterra Y-Block King
    Oct 7, 2005
    3,695
    87
    Hanson KY
    Not too bad. You may need a small prybar. And mark you shafts with a marker or paint so the steering wheel will index right.
  8. Stevodod
    Dec 30, 2014
    182
    Jacksonville, FL
    Thank GOD I just read this. THANKS Mark!!!
  9. Stevodod
    Dec 30, 2014
    182
    Jacksonville, FL
    Any tips on how to install the Borgeson Steering joint?
