Radio install
Discussion in 'General IH Tech' started by hst76, May 10, 2015.
  1. hst76
    hst76 Farmall Cub
    Jan 22, 2013
    140
    Garysburg, NC
    I have a Scout 800 I'm trying to put a radio in...but not in the stock spot-that would be way too easy and I like a challenge.
    Actually, the PO cut out all the louvers where the speaker used to be. So now I have a 7.5 x 4" hole in my dash...close to double din...but not quite. I am putting in a single din head unit and I want it to go back in that hole with, perhaps, a pocket under or over the radio. Of course, I want it to look nice, otherwise this task would be easy.
    I'd like to find a stock kit for some make of car that would give me the black plastic adapter with a prebuilt pocket. Unfortunately, unless I know a specific make/model of vehicle for the elusive adapter I am seeking, my searches are fruitless.
    Has anyone encountered this before? If so, what did you use?
  2. hst76
    hst76 Farmall Cub
    Jan 22, 2013
    140
    Garysburg, NC
  3. cudakota
    cudakota Farmall Cub
    Aug 19, 2012
    213
    22
    Long Beach, CA
    I've seen something similar on a 95 Accord.
  4. Mattd
    Mattd Farmall Cub
    Mar 9, 2006
    201
    22
    San Luis Obispo, CA
    I might suggest taking the dash and welding in the hole and cutting out the exact size for the stereo you buy.
  5. hst76
    hst76 Farmall Cub
    Jan 22, 2013
    140
    Garysburg, NC
    Thanks Mattd...I was actually trying to avoid that if possible. I think I found something, though.
  6. JordanAMC
    JordanAMC Binder Driver
    Mar 31, 2010
    733
    17
    Carrboro, NC
    Just got to walmart or similar retail store and look at the car audio section. They carry, in stock, many aftermarket radio install kits for various makes and models. I know Ford and most Jeep radios are double din, so they should work pretty well for you. They're relatively cheap, too. Try searching the web for say a 1998-2001, 2001-2004 explorer double din aftermarket radio install kit.
  7. Doc Stewart
    35
    Sounds like a day at the junkyard is in order!
  8. ScoutHI
    ScoutHI Farmall Cub
    Oct 7, 2013
    225
    Honolulu, HI
