Quarter panel patch, how to cover rocker panels
Discussion in 'General IH Tech' started by chopperroxie, Nov 10, 2015.
  1. chopperroxie
    chopperroxie Farmall Cub
    Nov 2, 2014
    263
    55
    Chalfont, PA
    I cut out and replaced the drivers side quarter panel patch on my 72 Scout II and used the repro patch panel from IH Parts. I had replaced the inner and outer rockers back in the summer since they were so rusted out but now I'm not sure what to do with that area in the wheel well where the rocker panel is open. Do I cover it with sheet metal? Any advice would be appreciated, picture below:
    Thanks guys
    Corey
  2. Gordon Pomp
    Gordon Pomp Farmall Cub
    May 28, 2015
    233
    42
    Redwood City, CA
    I need to replace that same area on my 78 (shocked, right?) I was going to cover mine in sheet metal after a thorough cleaning and an attempt to get the whole inside primered.
  3. chopperroxie
    Nov 2, 2014
    263
    55
    Chalfont, PA
    Thank Gordon. I got a internal frame coating from Eastwood that has a long nozzle that I planned on sticking inside both ends of the rocker panel and coat the crap out of it. And then try to cover it some way. I guess if I cut everything flush, a piece of sheetmetal would go over the whole area I guess.
  4. kevingweq
    kevingweq Y-Block King
    Nov 1, 2013
    3,036
    656
    Sudbury Mass
    This was some repair work I did on my Travelall ( same area) I ended up having to make a forming
    die for the patch piece , then made up some patches to cover the open rocker box
    Yep that is Eastwoods frame coating
  5. chopperroxie
    Nov 2, 2014
    263
    55
    Chalfont, PA
    That's exactly what I was looking for. Good job on that.
  6. BigRigg
    BigRigg Y-Block King
    Mar 12, 2004
    3,190
    598
    West Fork, AR
    I've been conflicted with this same thing. I think i am going to leave mine open and cut a piece out of the front inner fender that can be accessed. This will make cleaning out the rocker easy. I am also going to use the frame coat from eastwood and some fluid film inside. My thinking on the matter is I want to be able to clean it out with my pressure washer. Closing the ends will trap any moisture should any get in. Plus welding something in will cause flash rust inside, and start the rusting process almost immediately. Still up in the air about it all tho. I'm interested to see what you come up with.
  7. BigRigg
    Mar 12, 2004
    3,190
    598
    West Fork, AR
  8. RinTX
    1,846
    495
    A suggested modification. Leave a gap for drainage at the very bottom and bend the cover piece out ever so slightly so that the rocker is protected from most flying debris.
  9. chopperroxie
    Nov 2, 2014
    263
    55
    Chalfont, PA
    After thinking about it, and looking at that link you posted above, I'm kinda conflicted as well. Do I want to rustproof the inside and seal it up as a permanent rust proof job...if that's possible...or cut different drainage holes that I can plug with a rubber stopper and perform a yearly maintenance on them. I guess it depends on how much I plan on driving it in the mud/rain/snow/salt which is probably going to be quite alot.
  10. Sozzy
    Sozzy Farmall Cub
    Oct 7, 2015
    380
    74
    Southern Idaho
    I'll soon be in the same situation myself. I am leaning toward leaving some sort of access for water to escape and where I can apply por15 or similar. I'm liking the rubber plug idea.
  11. ddedman
    ddedman Farmall Cub
    Aug 27, 2008
    441
    Kalispell, MT
    Here's a crapp picture of mine closed off when I did my scout. I wasn't sure what it was supposed to look like seeing how it was all rusted away. I have seen a metal cap inset inside the rocker that had an access whole with plastic cover about one inch round installed in the ends. Not sure if it was stock or not. I wasn't and still am not happy with how my project finished out in regards to the rear Rockers and quarters. I have more pictures attached to the photobucket link on the below signature line.
